Need pics of cracked or broken engine crossmembers
Discussion in 'The Garage' started by 85m1009, Jan 6, 2004.
  1. 85m1009
    85m1009 1/2 ton status
    Jul 11, 2000
    718
    Missouri
    Like the title says, I need a good picture of an actual cracked engine crossmember. /forums/images/graemlins/thumb.gif
  2. dyeager535
    26,980
    I've got my old cracked one out of the truck, I might be able to get a picture of it tomorrow, if the snow melts lol.
  3. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    I have my engine out and can get you a pic today. It has cracked 3 times now and has been repaired twice. I will be replacing it with a homebrew crossmember this time.
  4. dyeager535
    26,980
    Any of the ones you replaced it with the "later" reinforced ones?
  5. Nonesuch
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    I never replaced it. I just welded it up. I knew that welding it would cause it to crack again but at the time it was the easiest way to repair it without any down time.
  6. dyeager535
    26,980
    Oops, pretty obvious re-reading your post, sorry.
    From what I've seen so far, the newer design is much better.
  7. dyeager535
    26,980
    Did you ever get a picture or you want me to go ahead and take one?
  8. Nonesuch
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    I have been slow at getting one as well. I have my rig covered with 3 different tarps and 8,000 straps to hold them on. Any pics I can get will probably be to dark to see.
