Need pics. of jack set up for dually
Discussion in 'The Garage' started by Eric M., Oct 2, 2006.
  1. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    Anyone have a dually with the stock jack set up? I'm pretty sure the jack and holder hardware on the drivers inner fender is all the same for 1/2 to 1 tons, single or dually. It's the jack handle and lug wrench set up on the passenger fender which I need to know. Again, the jack handles should all be the same, it's the lug wrench and holddown clamp that's got me confused. I think the lug wrench might be 2 parts. A deep wrench to extend into the rear dually wheels and it's a size larger than the single rear wheel 1 tons for the larger lug nuts. Then, a handle that fits into the end of the wrench.
    But what does it look like and how does it all fasten to the inner fender?
    Thanks,
    Eric M.
  2. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    Anyone??
  3. BadBob
    BadBob 1/2 ton status
    Aug 14, 2005
    158
    Lyndon, KS
    jack on drivers inner fender
    tire iron and crank on passenger fender
    behind battery if you can see the ends of the iron and rod
  4. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    Thanks!
    But, will that lug wrench really fit inside a rear dually wheel? The vacuum brake booster and the 81 and later style hood hinges I see in the pics. make me think this is a 1/2 or 3/4 ton.
    Eric M.
  5. ARAMP1
    ARAMP1 Aviator Extraordinaire
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    That's exactly the way my dually is set up.
    EDIT: Just re-read your post and you wanting the wrench side. The stock wrench didn't fit the ALCOA lug nuts, so it was tossed. I might be able to find a pic.
  6. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    What did the stock dually lug wrench look like? Was it 2 pieces or just a deep lug wrench?
    Thanks,
    Eric M.
  7. ARAMP1
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    Mine was just the one piece. I can't be 100% sure it was the stock jack though. I can't seem to find any pictures either.
