Need pics of the clutch master cylinder
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KRAZIE87K5, Apr 12, 2002.
  1. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    I ordered one from gmpartsdirect.com. I got it today... but there is no reservoir? Its got this goofy looking fitting in its place where you might connect a hose that is feeding hydralic fluid? What am I missing?
    If I had a few good pictures, I might be able to figure it out... or just a good decsription. Should I have a reservoir?
    Thanks! -Dan
  2. dyeager535
    26,976
    The reservoir is seperate. The S-10's look to use the same reservoir, and a simple clamp/rubber hose line to the master cylinder. Reservoir bolts to the wiper motor bolts IIRC.
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Dan, did you get the "rod" with the MC?
  4. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Yes I did Wes.... but now I need to find the reservior... Does anyone have that GM PN? /forums/images/icons/smile.gif /forums/images/icons/laugh.gif
    -Dan
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Cool on the "rod" thingie!! /forums/images/icons/wink.gif
    I will see what I can find out as far as a part number. Let me go downtown to GM... /forums/images/icons/wink.gif
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    use the image, it is off the GM parts computer
    item 30 from parts group....
    the stock one is small and cheap looking so no loss on using a home brewed one over it
    dam double negatives
