Need Pics Of Warn 8274 Mounts
Discussion in 'The Garage' started by mikey_d05, Feb 23, 2005.
  1. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    A friend of mine has a Warn 8274 in good condition for sale for $525. There's no way I'm gonna pass this up but I really don't wanna kill my approach angle when I mount it up. If anyone's running a Warn 8274 please post pics of your mount and how you did it.
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    here is one custom bumper i made, 8274 recessed into the grill so that there is only about 2" between it & the radiator
  3. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    ill try to get you some better ones. Its your standard warn bumper that i just took the middle out of it. THen set it on top of my frame rails.
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Here is mine on my burb
  5. 85scottsdale
    85scottsdale 1/2 ton status
    Dec 22, 2003
    283
    Lewisville, NC
    The easy way is how I did mine, not very tough bumper though on the side peices :frown1:
  6. white-rhyno
    Jan 27, 2002
    942
    ah ha, thats the bumper i used for pieces. instead of it sitting infront of your frame rails, take that middle piece off, remove your grill, and set it on top of your frame rails.then only the roller sticks out past your frame.
  7. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Actually by a strange twist of coincidence, I have access to a Warn bumper that was originally for a chevy but got chopped and narrowed for a Toyota. I could probably get it real cheap, cut the sides off like you did and somehow integrate the whole thing so it looked pretty good. Thanks for the photos and suggestions everyone.
  8. white-rhyno
    Jan 27, 2002
    942
    heres a bad photo of what i did. I have added alot more bracing. but i think you can get my idea.
  9. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Yeah, I get the idea. I'll probably leave the factory bumper there and just modify it to fit the new piece sitting on top, now that I look at it it really shouldn't be too hard. When you say you added more bracing, did you add more bracing to the bracket to beef it up, or did you add more mounting points between the bracket and the frame?
  10. white-rhyno
    Jan 27, 2002
    942
    Man, i was digging for a good pic that shows what i did to brace it. I did winch one time without the bracing. It actually didnt move that much, but i didnt trust it at all. Hope this helps.
  11. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Looks like you took a piece of plate and welded it to the front of your mounting box deal and then ran it down and bolted it to the frame, then welded a piece on top of the plate at a 90 degree angle. Not sure if this assumption is correct or not, I played with the picture for a while to lighten it up. Let me know if I'm wrong.
  12. white-rhyno
    Jan 27, 2002
    942
    yea you got it. its very stiff now. the one thats welded at a 90degree angle is because i needed to strength the spring mounts for the 56" spring swap. I didnt want to try to reuse that L bracket. The only downfall is that its all interconnected now. I cant exactly take the winch bumper off... But i dont i care.
  13. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Yeah, I'll probably do a similar setup, looks sweet, doesn't kill approach angle, and best of all, puts a beast of a winch on the front of your truck. :saweet: Thanks for all your help man.
  14. white-rhyno
    Jan 27, 2002
    942
  15. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Here is my homemade jobber for my Warn... It sticks out about 1.5" from the front of the frame rails, and the back of the winch is about an 2" from the radiator.
  16. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    most seem to be mounted on top of the frame rails... anyone sink it between them?
    j
