Need Pics of your inboard shock "Axle Mounts"
Discussion in 'The Garage' started by 88Silverado, May 22, 2006.
  1. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Hi all,
    Since I broke off the stock rear shock mount I decided to inboard the rears.
    I have 4" lift and the 8403 long shocks (probably why I broke the stock mount ;) ). The problem im having is determining what the best axle mount setup is. Ive still got the 10-bolt and really didnt want to cut one of the old stock mounts off but thought I could put new mounts on the opposite sides of the factory ones. Any problems with that? Any particular design or bracket I should use?
    I would like the option to retain the stock setup just incase this doesnt work out well for my DD and need to convert back, but if theres no way to do that...
    Also, is there any problem with the shock hitting the bump stop brackets during max compression?
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Weld on mounts from Kert
    My old shocks are pictured here but you get the idea. I know it looks like they will hit the bumpstop mounts, but I assure you that they will never hit.
  3. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    Now that's slick:bow:
  4. mostwanted
    mostwanted 1/2 ton status
    Feb 5, 2006
    765
    Kansas City, MO
    there fixed it for ya:wink1:
  5. readymix
    May 30, 2004
    6,706
    26
    All credit goes to Kert at DIY4x. All I did was a little drilling and booger welding.
  6. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Thanks DOOOOOOD:pimp:
  7. mostwanted
    Feb 5, 2006
    765
    Kansas City, MO
    are these bolt on or weld on?
  8. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    upper mounts bolted, lower mount is welded
  9. mostwanted
    Feb 5, 2006
    765
    Kansas City, MO
    well, I ment the upper mounts, anyhow. I figured on the welded lower:doah:
  10. readymix
    May 30, 2004
    6,706
    26
    The upper is a 3 piece bolt together system
  11. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    what is the benefit of the inboard mounting?
  12. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    The ability to run much longer shocks without poking holes in the floor or bed floor.
  13. littlejimmythatcould
    littlejimmythatcould 1/2 ton status
    Feb 6, 2006
    797
    Clovis, NM
    longer shocks mean more articulation?
    edit: yes that was a question.
  14. 88Silverado
    Mar 13, 2003
    2,664
  15. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Yes, but actually I would state it,
    Longer shocks means more articulation if your shocks were previously limiting suspension travel.
