Need plans for Electrolytic Tub...
Discussion in 'The Garage' started by PhoenixZorn, Apr 28, 2005.
  1. PhoenixZorn
    PhoenixZorn 1/2 ton status
    Mar 17, 2005
    1,734
    West Allis, WI
    I once saw plans for an electrolytic tub on some website, but now can't find it... it was built large enough to hold an entire car frame (or truck frame) and was built out of 2x4s and pond lining rubber... or similar materials...
    I've decided do build on of these things and start a rust removal service in my area, since there is no one currently doing it as far as I know. Besides that, I want to do my own frame before I have it powder coated by my uncle's shop.
    If anyone can get me that link, I'd appreciate it greatly... I originally found a reference to it on hk94.com, as someone was wondering how to get rust out of their barrels without ruining the bore... I am at work and can't go to weapon related sites, so someone please post up. =)
  2. dyeager535
    26,982
    191
    This work for you?
    "What is the method?
    Electrolysis is a technique for returning surface rust to iron. It uses the effect of an small low voltage electric current and a suitable electrolyte (solution). It has advantages over the old standbys, like vinegar, Coke, muriatic acid, Naval Jelly, wire brushing, sand blasting etc -- These methods all remove material to remove the rust, including un-rusted surfaces. With many, the metal is left with a "pickled" look or a characteristic color and texture. The electrolytic method removes nothing: by returning surface rust to metallic iron, rust scale is loosened and can be easily removed. Un-rusted metal is not affected in any way.
    What about screws, pivots, etc that are "rusted tight"?
    The method will frequently solve these problems, without the need for force, which can break things. Is it safe? The solutions used are not hazardous; the voltages and currents are low, so there is no electrical hazard. No noxious fumes are produced. The method is self limiting: it is impossible to over clean an object. Small amounts of hydrogen are emitted in the electrolysis process. Good ventilation or an outdoor work site is all that is needed.
    Where did this method come from?
    Electrolysis is a standard technique in the artifact restoration business. I wrote this up for the Chronicle of the Early American Industries Association a few years back. Most of the tool collectors around here use it.
    What do I need?
    A plastic tub; a stainless steel or iron electrode, water and washing soda (Arm & Hammer, for example) and a battery charger. About a tablespoon of soda to a gallon of water. If you have trouble locating the washing soda, others have reported success with baking soda. Also household lye will work just fine. It's a tad more nasty -- always wear eye protection and be sure to add the lye to the water (NOT water to lye!!!) The solution is weak, and is not harmful, though you might want to wear gloves. NOTE: It is the current that cleans, not the solution; nothing is gained by making a more concentrated solution -- DON'T!
    How long does the solution last?
    Forever, though the loosened rust will make it pretty disgusting after a while. Evaporation and electrolysis will deplete the water from the solution. Add water ONLY to bring the level back.
    What about the stainless/iron electrode?
    The electrode wants to be large (within reason); if possible, larger than the object being cleaned. The iron electrode works best if it "surrounds" the object to be cleaned, since the cleaning is "line of sight" to a certain extent. An iron electrode will be eaten away with time. Stainless steel has the advantage (some alloys, but not all) in that it is not eaten away. I have had good success with sheet stainless salvaged from a paper towel dispenser. It has a large surface area and is easily shaped to fit the container.
    How do I connect the battery charger?
    THE POLARITY IS CRUCIAL!! The iron or stainless electrode is connected to the positive (red) terminal. The object being cleaned, to the negative(black). Submerge the object, making sure you have good contact, which can be difficult with heavily rusted objects. Get it backwards and your object will be relentlessly eaten away! Make connections on a part of your electrode that protrudes out of the solution, or your clamps will erode rapidly.
    How do I know if it is working?
    Turn on the power. If your charger has a meter, be sure some current is flowing. Again, on heavily rusted objects, good electrical contact may be hard to make-it is essential. Multi-part objects may not have good electrical connections between them. Fine bubbles will rise from the object when cleaning is in progress.
    How long do I leave it?
    The time depends on the size of the object and of the iron electrode, and on the amount of rust. You will have to test the object by trying to wipe off the rust. If it is not completely clean, try again. Typical cleaning time for moderately rusted objects is a few hours. Heavily rusted objects can be left over night.
    How do I get the rust off after I remove the object?
    Rub the object under running water. A paper towel will help. For heavily rusted objects, a plastic pot scrubber can be used, carefully. Depending on the amount of original rust, you may have to re-treat. The amount of mechanical action will depend on the fragility of the object. Use your discretion.
    My object is too big to fit. Can I clean part of it?
    Yes. You can clean one end and then the other. Lap marks should be minimal if the cleaning was thorough.
    After I take it out, then what?
    The clean object will acquire surface rust very quickly, so wipe it dry and dry further in a warm oven or with a hair dryer/heat gun. You may want to apply a light oil or a coat of wax to prevent further rusting.
    Will the method remove pitting?
    No. It only operates on the rust in immediate contact with unrusted metal. What's gone is gone. What will it look like when I am done? The surface of rusted metal is left black. Rusted pits are still pits. Shiny unrusted metal is untouched.
    What about nickle plating, paint, japanning and the like?
    Sound plating will not be affected. Plating under which rust has penetrated will usually be lifted. The solution is likely to soften most paints.Test with a drop of solution in an inconspicuous place. Remove wood handles if possible before treating.
    How can I handle objects that are awkward to clean?
    There are lots of variants: suspending an electrode inside to clean a cavity in an object; using a sponge soaked in the electrolyte with a backing electrode to clean spots on large objects or things that shouldn't be submerged (like with lots of wood)
    How can I dispose of the solution?
    The bath will last until it gets so disgusting that you decide it is time for a fresh one. There is nothing especially nasty about it-it's mildly basic-so disposal is not a concern, except you may not want all the crud in your drains.
    Can I use metal containers?
    This is highly risky. Galvanized metal can introduce zinc into the solution. If you have used lye, it will attack aluminum. You may have problems with electrical shorts, etc. Stick to plastic.
    How can I clean odd shaped objects?
    Be ingenious. Plastic PVC pipe and eave troughs, wooden boxes with poly vapor barrier, kids wading pools, etc."
    from
    I know what it's like to be at work and bored. Enjoy. :)
  3. PhoenixZorn
    Mar 17, 2005
    1,734
    West Allis, WI
    Nah, but thanks... I found all that... I know how it works, just want to build a really big one.... with plumbing and all that jazz so I can keep reusing the same tub and keep it clean to a point... as soon as I find the plans, I'll post it here... I'm home now, so it won't be too long.
  4. PhoenixZorn
    Mar 17, 2005
    1,734
    West Allis, WI
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    seems to just be the same thing, no plumbing or anything. Filters would clog easily I'd think.
  6. diesel4me
    Jul 24, 2003
    17,584
    945
    Massachussetts
    antique restoration...
    I was watching a TV show the other night about lost treasure--they used that method to reclaim a civil war cannon and its cannonballs--the guy at the shop doing the electrolosis said they will leave the cannon in the bath for 3-5 YEARS!! :eek: :eek1: --I hope nobody is in a big hurry for their rust free parts! :thinking: :whistle:
    But the article you just posted says overnight should be long enough--I wonder how long it takes for real??....
    If this works I should drive my truck into a pool and hook up the wires,before any more of it rots off... :blush: :crazy:
  7. PhoenixZorn
    Mar 17, 2005
    1,734
    West Allis, WI
