need quadrajet help
Discussion in 'The Garage' started by jeff1976, Apr 20, 2002.
  1. jeff1976
    jeff1976 Registered Member
    Apr 20, 2002
    7
    Greenville, SC
    I got rid of my Edelbrock and installed a quadrajet. After talking to a couple of 4x4 shops, I did as they suggested and mounted the quadrajet backwards.(secondaries towards the front of the vehicle). I was trying my new set-up when I climbed a steep incline and ran into a small engine fire. Evidently, some fuel poured out of the carb and cought fire. Luckily I had my extinguisher handy and snuffed the fire but it had already destroyed my air filter and a vacuum line. Why did this happen and what can I do to fix it? Also, does anyone else run this setup?
  2. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    i do not know what caused that but i have never heard of mounting the carb backwards i ran an edelbrock for a while but went back to a qjet and havent had any trouble with it at all at any angle the edelbrock would cough and sputer anytime i hit a bump or try to climb a incline but even with the qjet mounted backasswards i dont know what could have happened
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    It sounds like the fuel leaked out the vent for the float bowl. I had problems w/ that (the motor would bog because the fuel splashed into the primaries) and solved it by putting a piece of fuel line to extend the breather.
  4. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    Why would you possibly want to mount your carb backwards? I have never heard of that before. It was designed to be installed one way and one way only. Your fire started probably because it was backwards. I would flip it back around if I were you and not listen to mechanics that tell you to put things on backwards.
  5. bogginnut
    bogginnut Registered Member
    Jan 6, 2002
    82
    Jacksonville, Florida
    I second Triaged fix of adding an extension to the vent
  6. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    Backwards, upside down, sideways, heck, whats the difference.. I am curious as to how you ran the linkage, especially if it is an automatic.
    John
  7. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    I've heard of turning a Q-jet around backwards.
    I don't see the point.
    With the secondaries in the front, and on a incline. They would run out-of fuel. Causeing a lean back-fire through the carb, possibly igniting any fuel that might be avalible.
    Trun it around, back to it's stock location.
    The primarie jets are more centered in the boal, and there is less of a chance of them running them dry. Even if they do, it's possible that the carb still won't run lean enough to cause a back-fire. (beacause at WOT, the primaries offer far-less air, when compared to the toilet boal secondaires)
    The only ressom I can think of, as to why someone would run a Q-jet backwards would be some kind of fuel spillage problem. Maybe, they think the fuel is spilling past the metering rods, or something? - I'm not sure.
