Need quick dash help please
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by '73 K5, Jul 27, 2001.
  1. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    I'm going to be removing my dashpad in a couple of hours to paint it, but it has a few small cracks in one area...the rest of the dash is fine. I was wondering how I could repair those cracks before I paint it. I was thinking of something like using silicone sealant and a putty knife and just filling them up that way and then painting over it. Any other ideas?
    '73 K5
    Chevy good...Ford bad
  2. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    If your cracks are small, you could probably use a repair kit. It comes with different colors of some kind of silicone (I think). You mix them to match your dash color and then apply it and cure it with heat (from an iron or somethink like that).
    I tried that on my old dash, but the cracks were too big and didn't work.
    <font color=purple>//////
    <a target="_blank" href=http://blazer79.freeyellow.com>blazer79.freeyellow.com</a></font color=purple><font color=black>
    Soon a 454 K5!!</font color=black>
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Paint won't stick to silicone sealants. [​IMG]
    Be really careful removing that dash pad. I just took the dash apart on an '88 Blazer that a friend is parting out and the dash pad literally crumbled as I took it off. [​IMG]
  4. Blazer79
    1,816
    Not sure if it's actually silicone in that kit, but since you can mix it up to match the color of your dash, it wont matter.
  5. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    one word BONDO
  6. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    How about two words: Custom Dash
    I not you can try those repair kits. The one thing that I have found is that if one portion of the dash is brittle enough to crack, other areas are not far behind. GM still sells dashpads, or you can by the covers that you glue/silicone into place.
    If you didn't build it yourself, how can you call it yours.......?
  7. rts
    rts Registered Member
    Jul 28, 2001
    15
    Dallas, TX
    I need to replace my dash pad this weekend. I picked up a new one from the Chevy house. ($115)
    Any tricks that I should know? it looks like it should come right out. Also, have you ever had one painted? Any tips there?
  8. TwoCrowsDesign
    TwoCrowsDesign 1/2 ton status
    Jul 13, 2001
    387
    I've seen paint that is designed to go over vinyl interior parts, but I've also seen it applied &amp; IMHO it looked like crap.
    However, that may have been the fault of the person applying it.
    John
