need quick help NOW!!!
Discussion in 'The Garage' started by buffblazer, Nov 24, 2005.
  1. buffblazer
    buffblazer 1/2 ton status
    Jan 5, 2005
    2,395
    Hudson Colorado
    ok i am replacing the dimmer switch on my 90 burb i removed the bolts that support the column and the hanes book says the column is supposed to drop down. but it wont :eek1: :confused: i moved it around and pulled on it but it wont drop down and i cant get to the bolts. i have to have this ready by friday afternoon and i wont have much time left to work on it so please help me tell me every possible scenerio
    thanks-craig
  2. jmd4x4
    jmd4x4 1/2 ton status
    Apr 4, 2005
    137
    Rosenberg TX
    There are 2 bolts in the engine conpartment right at the fire wall if you loosen those up then it should give you more room for you to work around your stearing colum. hope this helps.
    later
    jmd
  3. buffblazer
    Jan 5, 2005
    2,395
    Hudson Colorado
    thanks i will try that. if that dont work you got any other ideas
