need quick help re: 3/4 ton 14 bolt....already searched but in hurry
Discussion in 'The Garage' started by jakeslim, May 16, 2003.
  1. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    ok, i am back from driving all over town looking at 14 bolt rear ends from what the salvage yard claims are mid 70's 20 series 3/4 ton trucks. I found one 3/4 ton, but the shock mounts are on the opposite side of my current setup(12 bolt). I thought that 3/4 tons are on the same side? Also, is the spring perch gap between the 3/4 ton and 1 ton several inches difference(more that 1-2")?
    Please help...rented a van to haul what I thought was a find, but the first p.o.s. that i saw was a mess and had shock mounts on both sides....
    need some guidance from the "been through it" experts!
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    On my 3/4 ton 14b the shock mount on the pass side is on the front of the housing. It's out of a 78 Sub. As far as the perches go if they are in the wrong spot it may be a 1 ton axle.
    -Brian
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    1/2 ton an 3/4 ton have the same perch mount locations. 4wd or 2wd.
    1/2 ton an 1 ton do not. (unless you are running a first gen K5)
    If you pick up a 1 ton axle you will need to move the perches
    I don't know about your shock differences though. But shock mounts can be changed easier then spring perches.
  4. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    ok, i think both of the yards i went to were trying to sell me one tons as "3/4 tons". One guy was arguing with me and insisted that "ALL 14 bolts are the same, period and spring perchese are all the same".I advised him that they were not and he said "...its right here in my computer". #$%^&
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Hey is full of sh*t. He doesn't know what he is talking about and his computer is wrong. If you don't have the perch to perch measurement get it off your half ton axle. Measure middle of perch to middle of perch. Then when you find some 14bff's you measure the mid to mid perch and as long as they are within about 1/2" or so I think you should be fine.
  6. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Half-ton and 3/4 ton spring perch measurement is 42 1/2" center to center. That same measurement is 40 1/2" for the 1 ton 14 bolts.
