need roller cam recommendations
Discussion in 'The Garage' started by bigarmzz, Dec 12, 2005.
  1. bigarmzz
    bigarmzz 1/2 ton status
    Feb 21, 2005
    184
    elkins, west virginia
    i have a 350 roller motor from a 98 vortec truck....i'm converting it to run without a computer, and i'm using just a performer intake for the vortec heads to use a quadrajet....
    anyways, the cam in the motor now, dont have a mechanical fuel pump lobe, so i'm gonna have to buy an aftermarket cam....
    i want bottom end obviously, .....anyone have any numbers or recommmendations????
    my trucks an 85 bytheway:rolleyes:
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    call comp cams
  3. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    ditto, go for about 450 lift, and 206 duration@.050
  4. bigarmzz
    Feb 21, 2005
    184
    well, i called crane...all of there roller cams have got biggg lifts...over 550 to 700:eek1:
    comp said basically the same....
    so, i called pace performance...they said to go with the cam that is in the HT 383 crate motor...its 431/451 and 196/206 with a 109 lobe sep.
    here's the link
    http://www.paceparts.com/index.asp?PageAction=VIEWPROD&ProdID=22922
    its alot cheaper too...its only $142 v/s $259 for comp or crane:rolleyes:
  5. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    get a copy of desk top dyno and see which cam makes the best power for what you are doing with it. you can also call places like Bullet Cams and tell them what you do with the motor and they will grind you a custom cam for around 240.00. Comp cams did mine, 785 lift @320 duration on 114 lobe center.
  6. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
    MMMMM, maybe my crane hydraulic roller is a little too aggressive then? I mean, .700" lift seems like it may be a little too much for a truck motor, but mine seems to do ok. Seriously though, I have a Crane hydraulic roller that is .488/.509. Either you or the person you talked with at crane is confused. Jegs/summit have listings of most of the cams that crane makes.
  7. 1977k5
    May 26, 2003
    9,996
    134
    Don't get a cam because of price. The cam is one of the best place to pick up power and getting a cam that matches your motor perfect is well worth the extra $100. My cam is 276/284 adv. duration, 214/222 @ .050" .488"/.509" lift, Desktop Dyno rates it at 434 hp @ 5500 RPM and 470 ft.lbs. @ 4000 (440 + ft.lbs. @ 2000). Using desktop dyno it is just about the best match I could get without a custom grind. Mine has the same vortec heads, but its a 383. Your 350 will want a little less cam. Should give you some idea of the power you can make.
