Need screws for Warn hubs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, Jun 4, 2001.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I lost 5 of the screws that go on my standard Warn hubs. Anyone have some extras? thanks BTW I tried the old stock ones and they are really wrong.
    90K5
  2. TheGeneral
    TheGeneral 1/2 ton status
    Feb 22, 2001
    556
    NC, USA
    Hey, I stripped one out and was able to find a replacement at Lowe's in the specialty hardware (screws) section. All for 48 cents and brass even. If you don't have a lowes, let me know and I can probably mail in envelop.
    If you ain't hurt, you ain't playin' hard enough.
    The General
  3. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Most of 4x4 shops have Warn hub rebuild kits that have all the replacement hardware including the screws.
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I would try Lowe's, but I think those are weaker than the Warn screws. I also tried where I bought them, and they couldn't get them, but reccommended a place called Fastenall, that carries every size of screw or bolt anyone will ever need, except they didn't have them either...
    90K5
  5. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I have perchaced a rebuild kit from WARN. It cam with all the screws, retainer ring, snap ring and O ring. That would be your best bet. Anyplace that sells Warn hubs can get thease kit too.
    <A target="_blank" HREF=http://www.burt4x4.coloradok5.com>http://www.burt4x4.coloradok5.com</A>
  6. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    How did you lose 5 of the screws BTW??
    <A target="_blank" HREF=http://community.webshots.com/user/vwryda>http://community.webshots.com/user/vwryda</A>
  7. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I put the hubs on a few months ago. Then I took my truck to get the balljoints done...they supposedly aligned it, but did a crappy job. Took it back a couple weeks later to get it fixed, and they fixed it, but said my hubs weren't bolted on right. I reminded them that they did the balljoints, so they were tha last ones to have them out. after that, I pretty much forgot about it, then going down the street the other day, I heard a really bad clicking noise, and then the cap of the hub just popped off. I could only find one screw, and I'm pretty sure thats the only one that was in there.
    90K5
  8. Burt4x4
    6,854
    See!! ANOTHER perfict example of why I what to do EVERYTHING myself!! Damn hired help!! you just can't find good help thease days[​IMG]!!
    Well next time just do the research and takel the job your self!
    Good luck Bro!
  9. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Yeah.....I usually do the work myself, but heard what a PITA the balljoints are, and decided to take back the ones I'd been plannign to install...thye were sitting in the garage fo a few months. I knew I'd never get around to it...
    90K5
  10. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    The price shops charge for balljoint replacement, you should have done them yourself. It is not that bad of a job.
  11. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    I remember stripping my screws also and I went to the local hardware store and bought some new ones. I don't remember what grade they were and I'm sure that at that time I didn't even check(I was young), anyways I had them on there for a couple of years before I switch out the hubs again. If you think they aren't strong enough then just carry a few spare ones in the glove box just in case.
    <font color=blue>Esteban</font color=blue>
    <font color=red>SEMPER FI TO MY BLAZER
  12. tori89k5
    tori89k5 1/2 ton status
    Apr 12, 2001
    946
    Pismo Beach, California
    Dont mean to boost your post, but i need a new case for my premium warn hubs, you know.... the outter housing. So if anyone has an extra junk one, or knows for sure where i can find one.....
    New '90 K5 sitting in my driveway !!!
    <A target="_blank" HREF=http://www.tori89k5.coloradok5.com>http://www.tori89k5.coloradok5.com</A>
  13. Esteban86K5
    3,712
    Bakersfield, CA
    I might, let me check and I'll get back to ya later.
  14. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    The Advance Auto Parts store usually has rebuild kits, which include these bolts, typically in stock for the Warn hubs. The local NAPA store also had a Warn sign up.
    Basically, any parts store that carriers Warn products should be able to order these kits.
  15. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    The screws don't need to be very strong, they only hold the hub together. If the Loew one's are the right legth
    and thread per inch/cm, I give them a try, the real warn ones will not be less than 48 cents.
    Tip coat then with anti seize.
    Good luck
