Need Shock Relocation Pics ASAP
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Hossbaby50, Dec 25, 2002.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I need to see pics of installed shock relocation kits. i.e. 55Willys kit or MOO's kit. I just got my kit from Willy and I need to see how to mount it correctly in the standard position. Any advice on how you did it and problems you might have run into would be helpful too. But I definitly need PICS please. Thanks
    Harley
    P.S. Do you need a body lift to run one of these kits? Thanks again.
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
  3. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    Sorry but I have to ask is that Willys setup? And how is it working out for you so far?
    Eric
  4. chevyfumes
    Feb 24, 2000
    38,584
    266
    I't's 55's set up and it's not on mine it's BlazzinOr's but he said he liked it..... /forums/images/graemlins/thumb.gif
  5. Highlander
    Nov 25, 2000
    1,204
    Lakewood Colo
    Thanks for the info.
    Eric
  6. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Thast the pics of the one off set up I did for Frank, his exhaust was in the way for the other kit to work.
    Heres Scott's pics
  7. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Does anyone have it installed on a K5? I might have to install this kit with a behind the axle shock set up instead of the way MuddySub did with the infront because I don't think I can clear the mufflers. Anyone have pics of it mounted behind the axle and is there any possible problems with this? The only thing I can see sofar is the possible contact or tight clearence with the shocks and tank. Thank you.
    Harley
    P.S. BlazzinOr has a different custom set up them the normal one by 55Willy
  8. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    Pics of it sitting on my frame, you could mount it this way with the studs pointing out the back. just make sure the brakelines are out of the way before you weld near them!!!
    -Jeremy
