Need SM465 info
Discussion in 'The Garage' started by wayne, Jan 17, 2003.
  1. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Here are the ?'s:
    1. What is the first gear ratio?
    2. What years was it available with a hydro assist clutch?
    3. What years did they use a 208 case? Also what was the spline count?
    Thanks in advance.
  2. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,603
    556
    Wasilla AK,
    Not much help but the spline counts the same as th400 I had a208 behind A Th400 and it bolted right up to my buddies Sm465 I thinh hydralic clutches came out in 85-86?? can't rememer first gear 6.something /forums/images/graemlins/truck.gif
  3. Muley
    Muley 1/2 ton status
    Sep 26, 2002
    364
    Eagle Mountain, UT
    1. 6.55 to 1
    2. my 85 has a hydrolic clutch
    3. also ahs a 208 T-case, not sure o nthe spline count.
    All totaled out with my 3.73 gears ans 32's I have 63 to 1 crawl ratio. Not to bad for a stock rig.
  4. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
  5. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    The 208 was put behind the 465 starting in 81 (long 32 spline output)
    6.55:1 first gear
    Hydro clutch started in 85 or so
    Rene
  6. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    mine has 205 but its a 72forgot awhile ago. not sure of the spline though
    nathan
  7. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    The figure eight patteren 205 behind a SM465 is 11 spline. The round patteren 465 is long 32 spline.
  8. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    What Rene said...if it is a pre-1981 tranny, it will have a 10-spline output...all of them had a 10-spline input...
    Chris
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    there is 2 different size input shafts for a 465
  10. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    10spline on older ones,Early 80s went to 31.Have the gertrag 5spd with 241.broke it {241}.One off 92 465 bolted right on. /forums/images/graemlins/crazy.gif /forums/images/graemlins/truck.gif /forums/images/graemlins/thumb.gif Also found out slip yoke from mid 80s 205 will fit 241 and uses 1350 joint.
  11. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Ford has 31 spline inputs..chev is 32 spline (or 27 or 10)
    Rene
  12. ZonkRat
    Jan 16, 2003
    1,003
    Just traded for Ford 205,want to do 203-205 doubler or poss 241.Worried bout extra tourqe into 241 though.any comments.It's going behind Gertrag 5spd.I may be crazy,but,I like it. /forums/images/graemlins/crazy.gif /forums/images/graemlins/truck.gifer on 38s /forums/images/graemlins/thumb.gif
  13. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I wouldn't put a range box in front of a 241...I would use the 241 planetary set as a range box in front of a 205 though. The hard part is building it...
    Getrag is a nice shifting tranny, but the one piece aluminum design worries me. Plenty of fullsize Chev trucks running them though.
    Rene
  14. ZonkRat
    Jan 16, 2003
    1,003
    I have over 450,000 miles on mine,stillas tight and smooth as day one.Always heard they were junk{didn't believe}and wore out by 100 000.Have acess to 91 465,but, want to keep OD.Really want to do 203 dblr with Ford 205.Traded for one other day.Got to save for adapter kit.Bought 88 SWB new,still love it. /forums/images/graemlins/crazy.gif /forums/images/graemlins/truck.gifer in TENN
  15. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I think average life for the Getrag seems to be 140,000 miles and then they start to get difficult to shift when cold among other problems. I had one in an 88 GMC and liked it...but it was a 2WD truck. I'd like OD too, but the lack of a crawler gear makes it nearly useless to me.
    Rene
  16. ZonkRat
    Jan 16, 2003
    1,003
    Changing the gear fluid regular help shifting.Most use trans fluid.On bout 3rd change I went to hyd gear fluid.Same as used in systems that use same resivor for hydrolic cyl and gear box.States it's for use in gearbox assem.Been running this for 8yrs now and still works good.Change at least once a yr. /forums/images/graemlins/crazy.gif /forums/images/graemlins/truck.gifer /forums/images/graemlins/thumb.gif Still want doubler or granny gear though.
  17. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I think the 2 different 465 input shafts are both 10 spline but one is larger diameter
  18. Quack_Addict
    Quack_Addict 1/2 ton status
    Feb 24, 2002
    119
    Michigan
    1985 was the first year for the hydraulic clutch... but a linkage clutch SM-465 can be converted to run a hydraulic clutch assembly with a bell housing from a 1985 and later transmission.
  19. Ruff_ryda_420
    Ruff_ryda_420 Registered Member
    May 22, 2003
    19
    alberta
    ok, i've got a 78 blazer frame that came with a loose SM465/NP205 combo. i will very likley be using a S10 cab on it, can i use the S10 clutch mastercylinder, and will it adapt to the slave cylinder on a SM465?
  20. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    yes
