need some 10b hub help
Discussion in 'The Garage' started by sapper, Jun 2, 2004.
  1. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    I have been trying to get the hub off of my 8 lug 10 bolt for a hour now with no luck. The problem im having is once i take the locking mech. off i have a ring that runs on the outside of the hub, similar to the lock ring on the front of the steering box, how do i get that off without breaking it??? This is the first time iv tried messing with this so all the info i get will help. TIA
    oh yea the point of all this is getting the rotors off /forums/images/graemlins/hack.gif
  2. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    i use two mini screwdrivewrs.one to hold the ring from spinning in the hub then the other to pry under the snapring to lift it up a little.once u have it up a little you can take the one that you were using to keep the ring from moving andget under it farther in than the one that pried it up.you should be able to then pull the ring torward you slowly till it gets out of the groove that it stays in.then when you get that off the hub lock should come out.after that you take off the outer nut.i use a magnet to get the little spacer out.if it is stuck i hit it with a chisle lightly to brake it loose.then the inner nut can come off and the huib will then come off.just watch to make sure the outer bearing doesnt fall out in to the dirt.ask me how i know this.hahA.thats it,reverse that to get it all back in with proper torqueing technique /forums/images/graemlins/waytogo.gifs.
  3. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Yep, what he said, I also find it helpful to use a dental type pick to get under the lock ring to pull it out. Good luck /forums/images/graemlins/thumb.gif /forums/images/graemlins/usaflag.gif
  4. sapper
    Jul 11, 2001
    3,052
    NoVa
    you got that right, i will be adding those little picks in my tool box tomarow, i got the ring out and pulled the rest of the hub, then i found that i needed the 4 prong socket vice the six prong that i bought /forums/images/graemlins/1zhelp.gif but i should have brand new stopping power come saturday and them be able to take the kids to the beach, or wherever 79S wants to go look at /forums/images/graemlins/waytogo.gif
  5. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    Success, congrats! /forums/images/graemlins/waytogo.gif
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    A very small screwdriver, or even a pocket knife also work for getting that bugger out of there. /forums/images/graemlins/cool.gif
  7. chulisohombre
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    sorry i forgot to mention about the 4 prong hub nut wrench.the one you have is for the 14 bff nut.im glad you got it out. /forums/images/graemlins/peace.gif
