need some 700r4 help
Discussion in 'The Garage' started by MEPR, Mar 27, 2005.
  1. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    alrighty i wanted to know about what my rpm drop should be in 4th when my tc locks up. The blazer is on 31s whith 308 gears. At about 60 i see a drop of 200-300 rpm, but when im in 3rd ill see a drop of around 400-600rpm. is this kinda normal?
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yep, its normal. the drop depends on the stall ratio of the converter, a higher stall will have a higher drop when it locks up.
  3. karmannghia
    karmannghia Registered Member
    Mar 28, 2005
    5
    Stockton, Ca.
    700r4 Swap
    My friend just totaled his 92 shevy stepside. I have an 89 k5. Would his 700r4 trany fit in my truck? How about the computer module or anyother electrical hookups like that? I an not up on things like this.
  4. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    yes it will bolt in it is the same gm did not go to the 4L60E until 93
  5. fordeater
    fordeater 1/2 ton status Premium Member
    Mar 21, 2004
    1,402
    Missoula, Montana
    nice hijack
  6. karmannghia
    Mar 28, 2005
    5
    Stockton, Ca.
    Thanks I will tell him that he has to start parting out his truck so I can use hit Tranny
  7. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    so a diference of about 200rpm from 3rd to 4th is normal then?
