NEED some brake help...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazerBoy, Dec 20, 2000.
  1. BlazerBoy
    BlazerBoy 1/2 ton status
    639
    Chicago IL.
    I have had a heck ova week, first I smoke a front wheel bearing which locked the front wheel up, and then sheared my axel shaft in half because I was in 4x4. It messed up all kinds of stuff, I needed a new hub, Spindle, axel, bearings... wheew anyways Just before all of this non-sense, my brake pedal began to get soft and continually got worse it now does nothing until it hits the floor..... I checked the fluid and it is full, and I couldnt find any leaks, all of the lines are new. I was wondering what are the smymptoms of a bad Proportioning valve or a brake booster????
    BlazerBoy
    http://generalblueballs.coloradok5.com
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Usually when the pedal doesn't hold and slowly drops to the floor it is the Master cyl. loosing it's pressure!
    Good luck with the fron end rebuild!
    http://www.burt4x4.coloradok5.com
