need some CB help...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by StageZ, Nov 3, 2001.
  1. StageZ
    StageZ Registered Member
    Jul 2, 2001
    92
    Los angeles CA
    I just got a CB and am gettin too much ground noise... It sounds like I have a 2 stroke in the passenger seat.... I moved the ground from the floor to the battery and still no difference... any ideas how to get rid of that horrible ground noise? any suggestion would be appreciated... thanks in advance....
  2. Dip Stick
    Dip Stick Registered Member
    Oct 14, 2001
    73
    Murdock, Florida
    Try wiring in an engine noise filter, they're cheap I think...like 10 bucks or so. What type of cb is it?? I know some cobra's and midland's (Same thing, i know) Have a switch that helps cancel out some of the noise. Just what i know
    <font color=red> Live Fast, Love Hard, and Die Young </font color=red>
    1986 K20 & Lots of Rust
  3. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Or try posting in the communication forum
    You could even do a search, you might find this question there already.
    Red
    Still Poundin' "pavment" after all these years!!! [​IMG]
  4. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    The noise is comming from your alternator. Any power source inside your cab will have it. What you can do is wire direct to your battery. Make sure to take the wire and basically follow your headlight wiring to the battery. You know, over the wheel housing and behind the grill. If you go by the firewall, you'll pick up distributor noise.
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  5. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    try re routing the antenna cable, coax isnt perfect, it may not be in the power cable, but the antenna. there is, if i may say, an "antenna cable G-spot" in every vehicle, just have to find it.
    Tork DSR
    "Easy killer. That's technology you talk of..."
    http://www.torkpig.homestead.com
  6. COOTER
    COOTER Registered Member
    Sep 25, 2001
    49
    SOUTH EAST GEORGIA
    ALSO CHECK THE GOUNDS FROM THE ENGINE BLOCK TO THE FRAME.
  7. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    If the noise you are hearing is a whistling noise a noise supression filter may help. If it kind of like a static noise it could be just the way it is right now due to atmospheric conditions. If you set your SWR's and have the antenna and radio grounded good and you are still picking up a lot of noise that you can't squelch out then chances are it is the conditions. It may sound like a pain but if you are hearing this noise during the day go out about 3 AM and turn it on and see if it is still there. I bet it is much quieter.
    Also, what length is your coax and what kind is it? (ie:RG-58, RG-59, RG-58u, RG-58AU, etc) You need to have the coax at least 18 feet long. If it needs to be longer go in increments of 3 feet. That will keep the wave in check.
    John
    Like to go sloppin' 'round in da mud in a rapid fashion....=) [​IMG]
    <a target="_blank" href=http://community.webshots.com/user/chevyracing>http://community.webshots.com/user/chevyracing</a>
