need some driveshaft help
Discussion in 'The Garage' started by BIGDAN112686, Nov 16, 2003.
  1. BIGDAN112686
    BIGDAN112686 1/2 ton status
    Nov 20, 2002
    112
    nc
    alright, i just installed a 4 inch rough country lift on my 1990 blazer. it has a very slight vibe from 20-30, but thats liveable. the real problem is that when you take off teh gas at any speeds above 45, there is a sound that is like a loud click or somethin.(kinda sounds like its not set right) im also still ridin on 31's till tommorow. my questions, is this because the shaft is too short( stickin out about 2-3 inches longer that it was) or somethin else. i know its kinda vague, but if you need to know anything, tell me and ill answer. thanks in advance.
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Could be a little bind in the slip yoke. Have you lowered the T-case any? Lowering the T-case by an inch really helps the slip yoke do it's thing without binding and also helps with the driveshaft length some.
    Rene
  3. BIGDAN112686
    Nov 20, 2002
    112
    nc
    i havent lowered the t-case. would you suggest that over lengthening the driveshaft? also, would shims help at all? there are shims on the bottom of the spring pack, but i would say it was only about 3 or 4 degrees.
  4. BIGDAN112686
    Nov 20, 2002
    112
    nc
    also, is transfer case lowering easy to do? will this help with both driveshafts? thanks.
  5. BIGDAN112686
    Nov 20, 2002
    112
    nc
    someone please give me some help. im hopin to order whatever i need so that i can have it fixed asasp. thanks.
  6. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    go buy some 1" diameter or so poly bushings for anything, take them, and put them between the t-case x-member and the frame. and bolt it back up. as far as helping the front shaft- it will buyt could fun into front shaft problems if you have a 465/241 combo- in which case the front ashaft my hit the x-member.
  7. crazykev4x4
    crazykev4x4 1/2 ton status
    Jun 30, 2003
    430
    Watertown,Wisconsin
    lower the tcase it will help alot take the spacer from the top between the frame and nut and use that 1" spacer to space the crossmember a inch
    Kevin
  8. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    where in NC are you, i'll help you with anything you need done on the K5
  9. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    Kevin
    i don't recommend or accept this strategy.
  10. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    i must concur with bowtiered...never use just those spacers, they make the possibility of ripping the frame apart pretty good...get some bar stock steel or aluminum and use it...distributes the load MUCH better..
  11. crazykev4x4
    Jun 30, 2003
    430
    Watertown,Wisconsin
    just use the spacers to see if the vibe is gone then get something made that is solid to use as a spacer .
    Kevin
  12. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Here's a pic of my t-case and how it sits. I'm actaully planning to move it up.
    *does this look like it sits way too low in comparison to the frame???
  13. BIGDAN112686
    Nov 20, 2002
    112
    nc
