Need some fast help with my 14FF
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudFrog, Sep 23, 2001.
  1. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    First off I need to know how many quarts of gear oil it takes. Second off I wanna check the brakes since I'm just now putting the axle in. I took the axle shaft out but the drum will not budge. Is there a clip or something I'm missing that will allow it to come out? Do I need a special tool?
    89 K5 Silverado
    <a target="_blank" href=http://mudfrog.rockcrawler.com>http://mudfrog.rockcrawler.com</a>
  2. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    back the brake adjuster off some call it a star wheel
  3. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Take out the round clip, then the little rectangle thing (your screwed if you loose this) then back out the bearing nut. Theres a special socket for this but I used a flathead screwdriver and a hammer. Be VERY carefull when doing it this way. When you put it back together, tighten it enough to take out the wobble play then tighten it a little more until theres a slight bit of drag while spinning the hub, then just put the rectangle retainer back in and the clip.
  4. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    You need to pull the spindle nuts to get the drum off of a full floater - just like a front-end. As for oil capacity, if I remember right, they hold around 4 qts of oil.
    Special thanks to those lost from IAFF Locals 94 and 854 - You shall never be forgotten
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  5. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    the drum was a pain in the ass so i got a BFH and beat the bajessus out of is (getting disk brakes anyway), auto zone has the socket to get it off, i just rent it the part # at auto zone is #AZ840. it will say dana 70 socket but its the same. when taking off teh nut there is (should be) a snap ring w/ a little block holding the nut on---don't lose these, had a hard time finding a good one for a friend.
    Sun Desert Offroad <a target="_blank" href=http://4x4.alloffroad.com>4x4.alloffroad.com</a>
