Need some gauge help.
Discussion in 'The Garage' started by tdcombs, May 17, 2005.
  1. tdcombs
    tdcombs Registered Member
    Apr 12, 2005
    98
    missouri
    Read the thread on temp gauges and got my temp gauge to working. Now I still need to get my oil pressure gauge and volt gauges to working. Where do i need to start?
  2. dyeager535
    26,980
    Oil pressure gauge sender is at the back of the engine (typical) next to the distributor. Probably single prong connector, brown wire. Pull that off, with key in "run", touch that to ground, and see if gauge moves. If it does, sender problem, if not, wire or gauge issue. That should be your first test, although if the needle is "stuck" at something other than 0, turning the key to run should also "zero" the gauge.
    The voltage that the voltmeter "reads" is typically what also provides power to other gauges or lights, so that might be tied into the oil pressure issue. You'll need to pull the gauge cluster to check this though, you will need to verify the + on the printed circuit board is getting 12V with the key in "run".
  3. tdcombs
    Apr 12, 2005
    98
    missouri
    guess i forget to add that its on a 72 blazer. Someone told me the gauge is mechanical? What does mechanical mean?
  4. dyeager535
    26,980
    Well, disregard then lol.
    Oil pressure was mechanical until the late 70's sometime IIRC, so if it doesn't work, I'd have to say it's the gauge itself.
    I also believe your truck will have an ammeter, not voltmeter, so you'll have to get input from others that have experience with that setup.
  5. tdcombs
    Apr 12, 2005
    98
    missouri
    Thanks anyway, sorry i forgot the year in the origional post
  6. Boondocks
    Boondocks 1/2 ton status
    May 10, 2005
    129
    Massachusetts
    For the oil pressure, check that the copper line is connected to the driver's side of distributor.
    Ampmeter, there are two in-line fuses. one on each side of the radiator. They are short and the holder is a two piece rubber unit, that you can pull apart.
    I blow one or the other of those fuses all the time.
  7. tdcombs
    Apr 12, 2005
    98
    missouri
    One of the fuses was blown on the ampmeter and its working now that i replaced the fuse.
    The copper line is connected to the drivers side of the distributor. So does that mean its the gauge or could it still be something else?
  8. Boondocks
    May 10, 2005
    129
    Massachusetts
    You should check the full run of the tube to ensure it is not kinked anywhere.
    If you have access to another direct reading gauge, disconnect the tube from you dash mounted gauge and connect the other one and see if you get a reading.
    If that is not okay, maybe disconnect it at both ends and blow air through it to ensure it isn't clogged. But, I have never seen that happen.
    If all of that is good, I would say, yes, it is the gauge.
