NEED some help 350- 208 ???
Discussion in 'The Garage' started by doctor4x4, Feb 16, 2003.
  1. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    Yes I did search before posting this question.
    What is involved in swapping a th350 that was mated to a np203 in for one that is mated to a np208? Can I just swap it in with the proper factory 350-208 stock adapter that i all ready have or is the th350 output shaft length different ???
    Thanks in advance
    Randy
  2. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    Did 208's come behind 350's? I don't know.
    But we both know the output shaft on a 700r is alot longger than a 350/205 or a 203.
    I wish I could help you more....
    Eric
  3. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    you have to swap the output shaft from a th350 that when to a 208 and then use the 350/208 adaptor. i've done this, not hard but you do take the pump and all the innerds out of the trannie to do it. i had a dead th350 mated to a 208 the th350 had the lock up converter too, which i didn't like. i also had a 2wd th350 that was good so i swapped output shafts and put er all back together. worked great. its nice to have a t case you can hold in one hand and thread bolts with the other. try that with a 203!
