need some help fast
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by James90, Jul 17, 2000.
  1. James90
    James90 1/2 ton status
    May 18, 2000
    986
    Rocky Mount NC
    for the life of me I cant get the knob off my T-Case shifter how do you get that darn thing off? I have a stock 90 K5
    and thanks
    [​IMG]Go prepared
    I have a Shotgun a Rifle and a 4WD(K5) and Country Boy Can Survive!!!!
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Mine just unscrews off the rod. But I have an 84 with an NP208.
    YEEEEE HAWWWWW[​IMG]
  3. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Put an open end wrench on it and bang it with a rubber mallot. That should jar it loose.
    Boss
  4. bigjbear
    Feb 18, 2000
    13,971
    451
    Marietta GA
    Mine has a jam nut under the knob. If you loosen that first the knob will unscrew easer. Mine has a 205 but check under yours it might be assembeled the same. Jim.
    BigJBear '80 GMC
    http://www.bigjbear.coloradok5.com
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    You could also heat it up with a hairdryer for a while and then(with gloves on) spin it off........
  6. James90
    May 18, 2000
    986
    Rocky Mount NC
    thanks guys I will try that but mine just spins lose and dos not seem to unscrew
    [​IMG]Go prepared
  7. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    If it's like mine (NP-241), you might need to get a pair of vise-grips and clamp on REAL tight to the base of the shifter knob. Sounds like the insert has come loose. You might even be able to just pull up real hard and get the knob off and leave the little bolt.
    Worth a shot
    Kyle
    89K5
  8. James90
    May 18, 2000
    986
    Rocky Mount NC
    mine is an NP241 I will go try it
    [​IMG]Go prepared
