Need some help finding out wats grinding in the right front of my truck.
Discussion in 'The Garage' started by Chrisblazzer89, Dec 25, 2006.
  1. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    OK so i have an 88 blazer stock 10b F/R.
    Ok so now my front pass side is making grinding noise its fine wen i take off but like 20 mins into driving it starts griding.
    I just put in new manuel locking hubs (WARN PREMEUM) didnt repack the berings could that be it the berings?
  2. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
  3. W7NB
    W7NB 1/2 ton status
    Nov 9, 2006
    716
    Springtucky, OR
    What happens when you lock the hubs - does the noise go away?
  4. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    i havent tried that should i?
  5. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    Yea, you can give it a try......But if you take the bearings out, you should ALWAYS repack them, IMO, it can never hurt. Are you sure you got everything together right? I know when i put mine back together, it takes a little patience.....
  6. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    i didnt take out my bearings i just replaced the autolocking hubs with manuels
  7. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    Ahh, thats right, I did a lot more than that, which is why i had my bearings out......I think you should still pull em and repack em....
  8. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    i have never dont that be fore wat will i need and how should i do it
    off topic wat kind of silcone did u use to seal ur front diff wen u replaced ur fluid?
  9. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    Did you re-install the clip on the end of the axle before you put the outer half of the locking hubs on? If not the axle shaft can move inward some and bind and break a U-joint or even worse the axle itself.
  10. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
  11. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    Well, the only other thing i can say is i've had the stub axle rub on the inside of the locking hub and make some noise so you might want to pull the locking portion of the hub and check for any wear marks.
  12. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    I will do that while i wait for my carrier to dry off from all the brake cleaner. thanx
  13. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Hey guys is there anything I should look out for wen I clean out my front diff besides Wear and Tear on the R&P ?
  14. W7NB
    W7NB 1/2 ton status
    Nov 9, 2006
    716
    Springtucky, OR
    First off - pull the hub back off on the noisy side and check it. If you find metal fragments it's toast. I had one that even when properly installed would hang on the shaft and had to be replaced. I would NEVER pull a hub without repacking the bearings while I'm in there. They should be repacked at least once a year and even more often if you are in water alot. From experience I can tell you that while it's bad to chew a rear wheel bearing it's ROTTEN to chew a front. You will end up loosing the axle stub and all of the hub assembly at the very least, and if you sieze it up you will probably snap the u-joint and kiss the entire axle goodbye.
    Stop where you are at. Since you have the front diff open go ahead and pull the hub on the noisy side and pull out the axle. Check the axle bearing and seal on that side as well as the wheel bearing and races on both the axle and stub. Replace the axle seal while you are there and check for play or obvious wear in the u-joint and ball joints while you are there.
    A couple of extra hours in the garage beat a day broke down on the trail - or a $400 tow bill!
  15. Mr.Jimmy
    Mr.Jimmy Registered Member
    Nov 20, 2006
    66
    Albuquerque, NM
    dude! you gotta repack! plus check for proper tightness on them too! how long have you drove the truck? without being packed and snug, bearings go bad quick and make a grinding sound.
