need some help making some choices
Discussion in 'The Garage' started by BIG*RED, Dec 4, 2006.
  1. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    Hey guys, wanted to know some opinions..
    for those that don't know already I have an 82 k5, with 8 inch lift in the rear and 7 inch lift in the front. I need to correct some angles with the steering. Not ready to go crossover yet...so do I go with a drop draglink or a drop pitman arm?...I all ready have the raised steering arm..
    and where do i go to get a droped drag link and/or droped pitman arm?
    opinions and sugestions would be apreciated..as i've alomst got her back on the road..:wink1:
  2. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    a dropped pitman arm is better then a dropped drag link. the draglink can turn on its side therefore negating the drop. I ran the stock style push pull setup with 8" springs. I had a 4" raised arm and a 2" dropped arm. worked good and the angles were fine.
    Good luck. Is that you in your avatar?
  3. BIG*RED
    Mar 14, 2003
    1,094
    where do i find one of these droped pitman arms?
  4. Txchevy18
    Txchevy18 1/2 ton status
    Aug 29, 2006
    225
    Tx
    Most lift companies sell them for about 60 bucks or Im sure ORD can hook you up. FYI any 73-91 blazer , burban, or truck (stopping at 87 for the truck) will fit for your application.
