need some help on my front driveshaft
Discussion in 'The Garage' started by SUPERSUB87, Oct 22, 2006.
  1. SUPERSUB87
    SUPERSUB87 1/2 ton status
    Oct 16, 2006
    463
    TEXAS
    ok so i woke up late... around 3:40 :o.... so i walked out to the garage. installed the swaybar with the new brackets... installed the springs (with some issues) and got the axle back under the sub... but there i was one little problem... no matter how much i try to extend it... the front driveshaft will not reach the transfer case... it needed about 2 inches... then i tightened the u-bolts... put the tires back on... and now it needs around an inch to connect... anybody else encounter this... its a 6" rough country lift. if not... does anybody make a 1" spacer that i could buy for cheap?:confused: ?
  2. DirtyJim
    DirtyJim 1/2 ton status
    May 4, 2005
    665
    San Diego
    i had this problem too. i got the bds 6" and my front shaft didn't reach. dropped the t-case and everything. i had a new one made to reach the front 10bolt. keep the old one if you plan on running a D60. the one i had made was too long when i went to a D60. i had to go get another stock one.
  3. SUPERSUB87
    Oct 16, 2006
    463
    TEXAS
    sounds like the thing to do... i'm probably going to end up buying an 8" bds kit and put this one on my show burb later on. so the new driveshaft sounds good.
  4. DirtyJim
    May 4, 2005
    665
    San Diego
    measure carfully so you get a good amount of travel in your shaft.
  5. SUPERSUB87
    Oct 16, 2006
    463
    TEXAS
    yeah. but i really didnt want to spend that much money.
  6. SUPERSUB87
    Oct 16, 2006
    463
    TEXAS
    ok so superlift sells one... but with the shaft almost completely out... would it be ok for a trail rig? also... if i am to buy a driveshaft... would i have to buy new u-joints and how much altogether am i looking at for a regular lengthened driveshaft?
  7. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    I took mine down and it was 175 or 225 for a complete rebuild including a new slipyolk. i had mine done at Drivelines Inc in lake forest. great guy and good work. it is the 3rd driveline i have had him make or repair.
  8. SUPERSUB87
    Oct 16, 2006
    463
    TEXAS
    lake forest, ca?
  9. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    yep. Good ol Kalifornia. His name is Wade. If he needs measurements I can stop over there for ya. I need to go pick up extra joints from him.
  10. DirtyJim
    May 4, 2005
    665
    San Diego
    i had mine made at mack truck shop for 285. i told him to make it as stong as possible... now its laying in my garage collecting dust.
  11. SUPERSUB87
    Oct 16, 2006
    463
    TEXAS
    anybody in texas know of good shops???? i really want to do without the shipping
  12. SUPERSUB87
    Oct 16, 2006
    463
    TEXAS
    off topic... dirtyjim... how hard was it to install the body lift??? and do you like it... does it really mess up your center of gravity or can you tell? i might install a 3" on my burb so i was just wondering.
  13. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    texas is a whole nother country, i bet there lots o shops around. theres a driveshaft shop in san marcos. driveshafts unlimited i think. thats where my front is from, came with the truck, dont know the price.
  14. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    Open up the local yellow pages and start lookin for driveline shops. A local shop will be just fine.
  15. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Where in Texas are you located?
  16. goldwing2000
    goldwing2000 Guest
    What size u-joints are in it? Interested in selling? :D
  17. SUPERSUB87
    Oct 16, 2006
    463
    TEXAS
    right around victoria.
  18. KGsK5
    KGsK5 1/2 ton status
    Aug 26, 2006
    343
    Havre de Grace, Maryland
    im going to be installing a 6 inch lift and a D44 up front... i no someone said that the stock shaft could be used with a 60... but what about with a 44?
  19. Chaddy
    May 23, 2005
    4,110
    Salt Lake City,Utah
    yup. if you extend it
  20. SUPERSUB87
    Oct 16, 2006
    463
    TEXAS
    well... i have a d44.. my sub is a 3/4 ton and it needs another inch to reach. but i need my truck this week and i cant find out how to buy just a simple 1" driveshaft spacer from superlift for my sub... it's really starting to p!$$ me off!
