need some help with 12 bolt
Discussion in 'The Garage' started by luk3, Sep 8, 2003.
  1. luk3
    luk3 1/2 ton status
    Apr 29, 2002
    108
    idaho, USA
    i have a 12 bolt rear that makes a clunk noise when i put it into gear and reverse, i saw somone talking about it and they said u can fix it by welding the spyder gears, can somone tell me how or give me a link on how to do that.
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Here is the article, but it is for a 14BFF axle. /forums/images/graemlins/eek.gif I would not reccomend doing it to a 10 or 12 bolt axle. It puts a lot of stress on everything back there and it won't last long before it spits it's guts out on the street. Try searching the forums people have discussed this happening to them in the past /forums/images/graemlins/thumb.gif
  3. luk3
    luk3 1/2 ton status
    Apr 29, 2002
    108
    idaho, USA
    ok ty, any other way to fix it?
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Wait 'til it breaks and replace it with a 14 bolt FF (or a six lug 14 bolt SF or a 10 or 12 bolt if you so wish...that way you don't have to get new wheels). Honestly, rearends like the 10 bolt and 12 bolt aren't worth putting money into for how cheap a "new" one can be had.
  5. luk3
    luk3 1/2 ton status
    Apr 29, 2002
    108
    idaho, USA
    its on a 2wd truck with 280k on it its a 89 halfton
  6. heavy4x4
    Aug 28, 2002
    3,270
    It's not a 12 bolt then (unless it's been swapped). Check again, you've got a 10 bolt back there and will need a 10 bolt from an 88-on 1/2 ton pickup with the right gear ratio or from a '92-on fullsize blazer or suburban. Best to probably get one from a 2wd just incase there are some quirky differences like shock mounting. Oh, and with as many smashed/junked vehicles of the above mentioned era, I wouldn't put down more than $200 for the complete rearend at a junkyard.
  7. luk3
    luk3 1/2 ton status
    Apr 29, 2002
    108
    idaho, USA
    ya its a 10 i goofed, alrght i went to one junk yard then wanted 500 bucks for one.
  8. heavy4x4
    Aug 28, 2002
    3,270
    Ask them whether it's plated in 18 or 24 karat gold.
    Go to another junkyard.
  9. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    yep, old rear ends have slop, my 12 bolt does, and im proud to admit it. /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  10. luk3
    luk3 1/2 ton status
    Apr 29, 2002
    108
    idaho, USA
    lol hehe , yeah how do i find my ratio
  11. heavy4x4
    Aug 28, 2002
    3,270
    If it's the original axle, look in the glovebox...there's a list of 3 digit codes. Find the one(s) that starts with a "G" and post it. I'll tell you then what ratio you have.
    That's the fastest, easiest, cleanest way to get your ratio, but it probably wouldn't hurt to pull the cover off, drain the fluid, divide the number of teeth on the ring gear by the number on the pinion, and fill it back up. You'll be able to take a look at what's going on inside then too.
  12. luk3
    luk3 1/2 ton status
    Apr 29, 2002
    108
    idaho, USA
    ok ty ill go get it real fast
  13. luk3
    luk3 1/2 ton status
    Apr 29, 2002
    108
    idaho, USA
    does gt4 make sence?
  14. heavy4x4
    Aug 28, 2002
    3,270
