Need some help with my truck
Discussion in 'The Garage' started by Chrisblazzer89, Feb 25, 2007.
  1. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    OK I was wondering where my voltmeter needle should be? Mine is past 13 but not in the red is that OK? Second when I'm on the highway my truck vibrates for like 2 seconds and then stops the vibrates for 2 seconds then stops and so on and so on but everything seems to be fine what could be the problem? Third where can I find K5Blazer emblems like this one
  2. NewUser
    NewUser 1/2 ton status
    Feb 13, 2007
    528
    Chattanooga TN
    the vibration could be a U-joint or imbalanced driveshaft....as for the emblem im not sure...maybe somewhere like LMC? :dunno:
  3. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    Maybe wheel bearings?
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Volt meter reading just past 13 volts is good.
    Vibration seems to be driveshaft related.
    K5 emblem, try LMC or classicparts
  5. dyeager535
    26,979
    Gm still sells that emblem, gmpartsdirect.com has them for the same price as LMC, no idea if LMC is cheap knock offs or re-bagged GM pieces, but I'd go GM.
    Get a voltmeter on your alternator and see if your gauge is even correct.
  6. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
    HIGHJACK* - sorta...
    I just wired up an AutoMeter volt gauge that reads about 14.5 to 15 volts, that should be the norm right?
  7. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    anywhere from 13.5-15.5 is normal.
  8. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Thanks for all the help guys. When it gets warm out I will replace my conversion U-joint and replace all my bearings.
  9. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    Another thing..
    The slip yoke splines can get sloppy,and cause a vibration also,even if the u-joints and shaft are perfect...so can the pinion angle,if its not within specs..:crazy:
