need some help with removing front rotor.
Discussion in 'The Garage' started by chevyracing, Mar 24, 2002.
  1. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    This is a little off topic but it is my tow rig for my Blazer. I have a 99 1 ton dodge dually and need to replace my front rotors. I get the adapter for the wheels off okay and then the delima, how do you get the hub off to get the rotor off? I get the axle nut off and it seems that it is all pressed together. Do I pull the hub from the front or unbolt the 4 16 pt bolts from the rear.???? This is a cruel trick mopar played... Any help appreciated. Oh yeah, I guess it is pressed on, can I use the axle nut to press it back on? I can build a puller to yank it off without too much of a problem.
    John
