Need some help with window defogging
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ryan2286, Jun 3, 2003.
  1. Ryan2286
    Ryan2286 Registered Member
    Nov 7, 2002
    32
    South Suburbs of Chicago
    During the spring season lately my windshield has been fogging up badly. Usually at night when headlights glare off of the fogged up surface. I cant figure it out. I 'll run hot defrost, cold defrost, windows up windows down, heat, and vent, nothing works. I noticed something this morning aswell, I had it on cold defrost and I saw smoke coming out of the vents. AS soon as I saw this I shut off the blower and turned the setting to off. When I tried it again everything functioned normal with no smoke appearing. The blower pushes the air well and the heat works fine so what could be my problem? I'm tired of having to wipe down the inside of my windshield at every red light. thanks for any help or suggestions on where to start.
  2. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Sounds like you have ultra-high humidity in there.
    I wonder if your system has plugged drain holes.
    To keep my MX goggles from fogging I buff them with dish soap. Have no idea how that would work on a windshield /forums/images/graemlins/tongue.gif
  3. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,259
    72
    Humboldt/Pacifica, CA
    Just use Rain-X antifog on it. It's suppose to be the same as the dish soap/water solution.
  4. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Just to play Devil's Advocate: you don't have a heater core leak do you? /forums/images/graemlins/frown.gif
  5. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    I'll second the heater core leak.
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Vote number three for a heater core leak. That's a classic description of the problem. /forums/images/graemlins/shocked.gif
