Need some help..
Discussion in 'The Garage' started by Confedneck79K30, Feb 5, 2007.
  1. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    this weekend i need to rewire the starting system in my k10/30/whatever.... so i need to know what wires come from where and go to where, dealing in reference to that little junction block on the firewall...
    also, when wiring the electric fans and wiring to the relay, where do you wire which wires to on the relay?
  2. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    ttt, anyone have a wiring diagram for the starting system on an 86 k10?
  3. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    currently that is all ive got, see the cuttage? the one wire that looks like it's just slipped on (it is) with the blue crimp connector is one i found hangin loose, hooked it up and it starts and runs, but that cant be all there is to it... help!!
    also...
    what's this wire from the alternator do?
  4. SkysTheLimit
    SkysTheLimit 1/2 ton status
    May 23, 2003
    530
    Tampa, FL
    Now that's some weird stuff right there. I didn't see this post for some reason and asked the same question earlier today. I'll let you know if I find one and please do the same. :)
  5. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    deal, i may end up making my own wiring harness for it and add a push button... we shall see...
  6. SkysTheLimit
    May 23, 2003
    530
    Tampa, FL
    That's precisely what I plan to do down the road. I swapped out my TBI in favor of a carb and want to use my stock guages, switches and such for now. Eventually I want pushbutton start and a full toggle panel for all electronic functions in the truck.
  7. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    I have 2 wiring diagrams for an 86 k5 saved on my computer but they are pdfs so I cant post em up. If you PM me you email addy I can email em to ya.
  8. SkysTheLimit
    May 23, 2003
    530
    Tampa, FL
    Much obliged. PM on it's way!
  9. Tominator II
    Tominator II 1/2 ton status
    Nov 5, 2005
    280
    South Park CO 80440
    You should just put a Starter solenoid next to your Battery and run the ignition and starter/battery wires to it, then the starter. It makes tuneups and distributor/engine work easy too.
