Need some help??
Discussion in 'Rocky Mountain Region' started by therobzilla, Jan 5, 2004.
  1. therobzilla
    therobzilla 1/2 ton status
    May 15, 2001
    1,307
    Gilbert, AZ
    OK,
    If you have not heard yet, yesterday's trip out to Florence was ugly for therobzilla, I really lost the CHI, must have given it to Eric..
    For all that did not hear, broke 3 axles on same trail all in same day..... Both front axles and a rear 12bolt.
    I usually have a pretty decent supply of d44 shafts, but lately my short side inner supply is a little low, especially after the last month of wheeling. Hell this month I have broken 5 shafts alone.
    I need at least 2 short side inner shafts and at least one more long side inner. I have plenty of outer stub shafts, but don't have any more short inners left. I was really hoping that I could find some of these locally. Can anyone hook a brother up??
    I am going to swap in a set of Superior Crmo shafts with CTM's but the CTM's have a month leasd time.
    Please post up if you have a shaft or a set of shafts you are willing to part with, and maybe we can cut a deal....
    Thanks guys!!!!
    Rob
  2. Moose
    Moose 1/2 ton status
    1,062
    Glendale, Arizona
    Rob hey, A guy here at work has a set of axles(44 front rotor to rotor and a 12 bolt reare drum to drum) for $ /forums/images/graemlins/usaflag.gif /forums/images/graemlins/burb.gif200.00
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I'll try and swing past Ecology and the other little you pull it tomorrow after work and will see what I can see for you Rob. If I find any I will pick them up for you.
    Harley
  4. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    I have a complete 44 sitting under my suburban that I won't be needing much longer. The only thing I see being a problem is the time until its out of the truck. From my conversion with Grant, it sounded like you need axles asap. (the weekend mainly). I don't know, but I'm open to almost anything. I can pm you with my cell # if you wanta talk. Or I can call you.
  5. 77ChevyK10
    77ChevyK10 1/2 ton status
    Feb 2, 2003
    317
    Laveen, AZ
    ok
    dont for get the shakle blot you sheared.
    Andrew
  6. therobzilla
    May 15, 2001
    1,307
    Gilbert, AZ
    Brian,
    I PMed you..
    Rob
  7. Jays Beast
    Jays Beast 1/2 ton status
    Aug 7, 2002
    538
    Chandler, AZ
    Rob sent ya a PM.
  8. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I went past Ecology today after work along with the yard just south of them. Scouting report:
    Ecology:
    2 complete D44's (one w/flat tops)
    1 complete 12 bolt 6 lug axle
    $36 per axleshaft (inner and outer)
    $23 per rear axleshaft
    Other yard:
    1 shortside D44 axleshaft available (w/flat tops)
    forgot to ask $, but probably similar
    FYI: 1/2 OFF day at Ecology is going to be January 17th so if you can wait that long and they are still there they are 1/2 off.
    If you want me to pull them or if you want help pulling them then let me know.
    Harley
  9. therobzilla
    May 15, 2001
    1,307
    Gilbert, AZ
    Thanks for the heads up, looks like I will be heading to the junk yard for some shafts.
    Harley, send you a PM.
    Rob
