Need some input..quick
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by ta70cst, Jan 9, 2002.
  1. ta70cst
    ta70cst Registered Member
    Nov 14, 2001
    28
    Colorado
    Guys,
    My Blazer is stalling after I hit bumps... even speed bumps in parking lots...Any thoughts??? Anything will help...
    Thanks,
    Tom
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  3. ta70cst
    Nov 14, 2001
    28
    Colorado
    It just dies with no sputtering and then I just have been sticking it in neutral and starting it back up again...Also, it does it when the car is all warmed up.. I might think it would do it just because I have not given it proper time to warm up but that is not the case... oil pressure and temp all look fine. thanks for the responce...
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  5. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    Does it have an Edelbrock carburetor on it? I'm being serious....I've got an Edelbrock 1407 (750CFM) on mine and it's miserable on anything bumpy.....stalls, sputters, etc. And when I'm actually trying to climb hills offroad.....it's a total "flood fest".....more stalling and flooding.
    They make an "offroad kit" which supposedly helps, and it's cheap (like $15) you could also have someone who knows about carbs check the float levels to make sure they're not out of whack.
    -Greg72
    '72 K5 Blazer - 427BB/TH350/NP205/6" Lift/35x12.50's
    <font color=blue>See it here: </font color=blue><a target="_blank" href=http://coloradok5.com/gallery/albun38>http://coloradok5.com/gallery/albun38</a>
  6. ErikH
    ErikH 1/2 ton status
    May 15, 2001
    112
    Southern California
    It's likely something electrical as stated.
    I also have an Edelbrock carb (1405), and I've found it totally reliable offroad, even on steep low-4 climbs. I recently lowered the floats 1/16", but just as a precaution. I like the simplicity of the Edelbrock.
  7. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i have the 600cfm on mine and never had any problems with it and now it wont quit flooding out on inclines and declines and they dont have to be steep either lol it also has the manual chock and i have lowerd the float level on it also has the offroad needle and seat set and was rebuilt les than a year ago
    wheeling videoshttp://community.webshots.com/user/ssmith6333
  8. wrath
    wrath 1/2 ton status
    Mar 4, 2001
    182
    Grayling,Michigan
    Hei,or points?check all your main power wires..if its hei make sure your main power is snug.
    70K5 350ci.350/205 "PROJECT 40"BOGGERS" It runs and its clean !!
    <a target="_blank" href=http://communities.msn.com/OurMudToys/the70k5blazer.msnw>http://communities.msn.com/OurMudToys/the70k5blazer.msnw</a>
  9. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    My truck was dieing when it was hot. It turned out to be the ignition switch and the plug into the back of the switch.
    '69 K-5/350/TH350/35's & 6" Lift
  10. ta70cst
    Nov 14, 2001
    28
    Colorado
    thanks
    Thanks for the responces... I am checking out my float and will also be inspecting the electrical.... thanks again..ta.
