Need some long ass brake lines for 52's up front....
Discussion in 'The Garage' started by stallion85, Jul 25, 2006.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Where did you guys get them? I have seen Superlift makes them for a 12" lift, but is this going to cut it? Links would be greatly appreciated as I am under the influence and don't want to read that much........:p:
  2. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,602
    554
    Wasilla AK,
    they should work I have them with 12" springs 1.5 longer shackles and a 1'' zero rate and I run a small 6" Bungee cord between the 2 to keep them out of the tires
  3. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Dig it......
  4. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Where did you buy yours?
  5. yellowK20
    Dec 26, 2002
    7,602
    554
    Wasilla AK,
    NTWonline.com Not sure on price it's been 5years or so
  6. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    I think I got a few extra new ones. They are either 32" or 34" if you are puttin them on your d60 then the 10bolt banjo's will work with them. let me know if they will work and I will look around for them.
  7. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
  8. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    PM sent thank Toby:wink1:
  9. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i got mine from shane74 (vender) on here. grea guy to do business with. bought gears and locker from him as well
  10. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I run the superlift ones for a 12" lift. At full droop they are just about tight.
    So if you can get longer ones.
  11. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    second vote for shane74 I have never bought from him but he got back to me quick when I asked a question about pricing
  12. Emmettology 101
    May 9, 2000
    8,126
    FL
    Supporting a board vendor is always a good way to go.
    Although another line routing option would be to route your lines like the rears. Have the main line come off the master to a frame/crossmember and then have one flex line in the middle of the chassis down to a "T" on the axle. The run the lines from the "T" to the calipers. That way you only need one flex line that doesn't need to be so long..
  13. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    You will need 3 flex lines, obviously one long one for the middle and a couple of short ones for the calipers. I considered doing a center drop for mine but I took the lazy way out and decided longer lines with some springs attached to the shocks would be the easier way to go. I had a local company called deering industries make my lines, iirrc they were something like 36" long. I got the lines that were kevlar coated.
    I initially looked at the 12" superlift lines but they would have just barely been too short. And for the kevlar coated superlift lines they were way more than what i paid at deering industries.
  14. Emmettology 101
    May 9, 2000
    8,126
    FL
    Yes, 3 flex... But only one long flex to worry about(getting pulled off, etc.). Unlike two to worry about in a conventional set-up. :)
