need some measurements from a stock K5...
Discussion in 'The Garage' started by jekbrown, Mar 20, 2007.
  1. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    hey gang. I need some measurements of a stock 2nd gen K5. Here is what I need, within an inch or so...
    1) overall width (not including mirrors) of the body, where ever its widest.
    2) rocker panel height from the ground
    3) height to the top of the roof.
    4) height to the place on the seat where your butt goes.
    can anyone help me out?
    j
  2. thfonz98
    thfonz98 1/2 ton status
    Feb 19, 2005
    319
    Salinas, ca
    if i could find my misplaced measuring tapes id help. sorry
    its what happens when the roommate's girlfriend cleans the whole house.
  3. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,925
    337
    Fort McMurray, Alberta
    I'll take a couple measurements today -- Can't measure the seat height though, my K5 has no seats, lol :D
  4. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    thanks for the help guys. One more measurement....
    5) height to the floor (where the seats mount) from the ground.
    even without a seat you can get this one SC. :thumb: :grin:
    j
  5. dyeager535
    26,980
    I've gotta work on my truck late (:()tonight, probably can't get widest point by myself, but the others I can handle if you still need it by then.
    You say stock truck. Stock with 235/75R15's, stock with 31's, base or HD suspension, weight, etc?
    I know it sounds like I'm being nit picky, but if you need within an inch, all of those are going to screw the overall height up. I suspect a 5700lb heavily optioned base suspension truck on 235's is going to be considerably less tall than a bare bones truck @ 5000lbs that came on 31's. For whatever you are considering, is any of that important?
    Mines HD suspension, 5000lbs, on 33's, but the tire issue is an easy one to solve. All stock parts except the tires and an add-a-leaf that brought the sagging rear level, so it's going to be "true". About 7/8 of a 31 gallon tank of gas as well.
  6. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    stock with 31s. I know there are other factors that can determine various things... but its all good. If I get a couple of different sets of numbers, I can average them. :)
    j
  7. Russell
    Jun 23, 2000
    7,925
    337
    Ah, mine has 235s on it, won't work too good for you then...
  8. dyeager535
    26,980
    235's are what, 29" theoretically?
    Still easy to calc whatever measurements he needs from the tire size, if precision isn't THAT important or he's going to average.
  9. Russell
    Jun 23, 2000
    7,925
    337
    probally right :D
    I'll run out and grab the measurements right now
  10. Russell
    Jun 23, 2000
    7,925
    337
    Ok, here we go:
    1) Overall width from bodyline to body line is approx 80", plus or minus 2 - 3" cause its tough to see where the other side of the tape is :D
    2) Height from the ground to the bottom of the rockers is 18", plus or minus an inch
    3) Height from the ground to the floor pan is 23" plus or minus an inch
    4) Height from the ground to the roof is about 6'1" plus or minus an inch.
  11. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    noted! thanks much mang. Can anyone else grab some real quick? I think I will average things and add/subtract height based on tire height if need be. If you're gonna post up some numbers, just don't forget to mention what tires ya have...
    j
  12. Russell
    Jun 23, 2000
    7,925
    337
    Ah, right, that is a 85 K5 with stock 235s. Had a diesel from the factory, still has the HD suspension with the 305 it has now though.
  13. dyeager535
    26,980
    Looks like it will be tomorrow night before I get a chance to work on it, if thats ok?
  14. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    no worries at all dude... take all the time ya need! :)
    j
  15. dyeager535
    26,980
    I got 79.25" measuring from the rear wheel well "flare", or 80.25" body line to body line. I'm more comfortable with the first number though, I was able to get a straight piece of wood completely underneath right at that level, so that measurement should be real close. Maybe 3/4-1" narrower if you remove the wheel well trim. As with Sierraclassic, hard to know how close I was on the BL to BL measurement.
    19.75"
    76"
    36.25" High Back buckets.
    24.75" This measurement is kind of subjective. The seat bolts/mounts actually are "bulged" inside the cab. From underneath, they are probably about 1/2" higher than the floor pan, which is what the 24.75" measurement is. But it was taken right at the edge of the bulge.
  16. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    awesome mang, thanks much. anyone else wanna hook a brotha up??
    j
  17. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    one more please? :)
    j
