Need some measurements!
Discussion in 'The Garage' started by BowtieBlazer, Apr 26, 2002.
  1. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    Okay I am trying to get some numbers on the roof height of a blazer depending on a few variables. I took rough measurements and thats all that I really need along with some basic variables. Here is how I measured mine from the ground to roof @ rear window, ground to roof @ front of driverside door.
    Lift:
    Tire size: ( just what they claim to be not real height)
    Axles:
    Rim Dimensions:
    Ground - roof (rear):
    Ground - roof (front door):
    Lift: stock
    Tire size: 31" x 10.50
    Axles: 10 bolts
    Rim Dimensions: 15 x 10
    Ground - roof (rear): 72" (6ft)
    Ground - roof (front door): 73" (6ft one inch)
    I am just looking for rough measurements to get a avg number. It really took me 5min to walk to my truck grab a tape measure and walk back inside. Any help is greatly appreciated.
  2. mdm365
    mdm365 1/2 ton status
    Jul 2, 2001
    536
    mineral wells wv
    mine has a 4'' lift with a 44 in front 12 bolt in back 33x12.50 15x10 rims I have 6'6'' at the door and 6' 4'' at the back.hope this helps mike in lasvegas.
  3. Grim-Reaper
    7,385
    Atlanta
    6ft 11 inches on mine.
    1 inch body lift.
    5 inches of total suspension lift over stock on the front.
    6 inches of total suspension lift on the rear.
    35 inch BFG KM's on 15x10 rims.
    The suspension is actual lift over a stock 79. With Hard top on. The rear came up about 1 inch when the hard top came off.
  4. BowtieBlazer
    Jul 15, 2001
    2,462
    Thanks for the measurements mike!
    Anyone else? If I get enough replies I will make some sort of table sorting out all the info for future user refrence.
  5. BowtieBlazer
    Jul 15, 2001
    2,462
    Thanks as well grimmy!
  6. tRustyK5
    Jul 23, 2000
    36,169
    1,369
    E-town baby!
    Lift: 4" Rancho (old...) 1" ORD body lift
    Tire size: 36 x12.5 TSL's
    Axles: 14 bolt FF rear, D44 8 lug front
    Rim Dimensions: 15x10's
    Ground - roof (rear): 81"
    Ground - roof (front door): 81"
    Rene
  7. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    lift: 6'' tc ez-ride front, shackle flip + 1 1/2'' block rear, Tire: 35x12.5 Mickey Thompson, Axles: 10 bolt front 12 bolt rear, Ground to roof at drivers door: 83'' (6' 11''). I couldn't tell you what it is at the rear because my top is off right now.
  8. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    86 K5. 4" procomp lift (springs front, blocks rear) 35" BFG muds fairly new, and 10 bolt axles. 79" at the roof above front door, 80" at the back. Just so you know how I measured I layed a 2x4 across the roof and measured from the ground to it, so fairly accurate
  9. BowtieBlazer
    Jul 15, 2001
    2,462
    Thank you! thank you! thank you! Those of you that have a few spare moments this weekend I would really appreciate it. I will compile this info and I'm sure it will be useful to others at some time or another. Man some of these rigs are becoming much taller than I ever expected the roof lines to be.
  10. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    I have my top off("73)but I have 80" to the top of the windhield frame at the door.Just out of curiosisty how high are you guys at the top of the bed rails.I am 58".This is at the tailgate.
  11. Brady
    May 6, 2000
    628
    Parachute,Co
    Oh yeah old rancho 2.5 " springs and 2" longer shackles in front.2.5 " springs and 2" blocks in rear.36" swampers.44 front 12 bolt rear.
  12. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    89 Blazer.
    Lift: add a leafs
    Tire size: 33x12.50
    Axles: 10 bolts
    Rim Dimensions: 15 x8
    Ground - roof (rear): 75"
    Ground - roof (front door) 75"
    Oh. and for Brady I am 53" to the top of the tail gate
  13. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
  14. tRustyK5
    Jul 23, 2000
    36,169
    1,369
    E-town baby!
    Brady...mine is 58 1/2" at the tailgate. That's with my hardtop on and probably 200 lbs of junk in the back of the truck.
    Rene
  15. BowtieBlazer
    Jul 15, 2001
    2,462
    I just measured about 50 1/2" - 51" to the top of my tailgate hard to say my truck is sort of sitting on uneven ground right now.
  16. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    '90 Jimmy
    6" BDS all spring lift
    60/14
    ORD Extended front Shackles
    37" SSR's
    16" rims
    83" top
    61" tail gate
