Need some oil cooler help
Discussion in 'The Garage' started by afroman006, Aug 15, 2005.
  1. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    I'm running a 6.2 in my trail truck but am using a radiator out of a 91 C/k series 1 ton that had a 454 and auto in it. The radiator has tranny and oil coolers but I'm having trouble with the oil cooler. The engine had the fittings with 90 degree bends and barb hose fittings when I got it but I dont have the barb fittings for the radiator end. I think I need the type of fitting where it has the tube in the middle and the tube has a shoulder. Unfortunately, none of my currents parts trucks have oil coolers on them so thats not an option. I do know that the head of the fittings I need is 3/4", because I had to remove a twisted off hardline remnant from the radiator. Does anyone know where I can get these type of fittings? Thanks
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I usually get that kind of stuff from Earl's Performance over here. Pretty sure they're in your country too.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    If you can get an old set of factory hard lines then any shop that makes hydraulic hoses can hook you up with a leak proof setup. The fittings at the radiator are a GM oddity, with O-rings to seal them. :mad:
  4. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I'd take it out of the radiator completely. Use a stacked plate separate oil cooler.
  5. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    id go with external oil cooler too, spend the little extra for the plate one-not tube
