Need some opinions on the 6.5TD. Edited for another question
Discussion in '1982-Present GM Diesel' started by Dirty Dave, Jul 26, 2003.
  1. Dirty Dave
    Dirty Dave 1/2 ton status
    Dec 21, 2001
    101
    Kentucky
    I am looking at purchasing a 97 3/4 ton with a 6.5. Does anyone have anything good or bad to say about them. I love the 6.2 in my CUCV but EVERYONE in my area that has had a 6.5TD including my dad has had trouble.
    The price is right though. So let me hear some opinions and thoughts.
  2. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Re: Need some opinions on the 6.5TD.
    It has an electronic pump and those have been known to be troublesome. It would be an all right engine if you converted over to a purely mechanical pump.
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    How feasible is converting to a purely mechanical pump? I can't see it being easy when a 4L80E is in the mix... but maybe with a manual trans or good 'ol TH400. Change the "fly by wire" accelerator pedal over to a linkage type... what else? /forums/images/graemlins/thinking.gif
  4. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    The later 6.5 have had some issues, but nothing that can't be taken care of. The PMDs (injection pump controller) fail from over heating; they can be relocated. The electric delivery pump can fail, but this is "usually" a power failure of the oil pressure switch; install a relay between the OP switch and the pump.
    In all they are stronger block, more powerful version of the 6.2. I'ld snap it up /forums/images/graemlins/thumb.gif
  5. bigblock454
    bigblock454 Clack Clack Clack Premium Member
    Jun 18, 2002
    546
    16
    Terre Haute IN
    Also check to see if it has the Green Tag injector pump. The green tag pumps are guaranteed from GM for 11 years and 120K miles. Green Tag is the third generation pump, the first 2 were fairly problematic. They also make an aftermarket cooler for the pump controller. Check out www.thedieselpage.com for further information.
  6. BlueBlazer
    Feb 15, 2001
    1,940
    I dont think it would be very easy either, but Im sure there are many that have done it and had it work out well for them. I would think most of the parts needed would be available over a GM parts counter like the accelerator cable and such. The ECM most likely only looks at the TPS in the pedal to control trans. operation. Maybe there is a way to leave that and hook a cable to it. Someone who has actually done this needs to chime in with some better answers since I have no experience with it.
  7. Dirty Dave
    Dec 21, 2001
    101
    Kentucky
    I called the place today and they told me that an error had been made by the paper and it was actually a 95. The price is still good though.
    Dan mentioned above that the later 6.5's had some issues. Is the 95 earlier enough to be with out so many issues?
  8. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    The '95 is a plus as far as the dash is the updated style. The injection system is the same as the '94, problematic. IMO, still worth pursuing if the truck fills your needs.
    Swapping to a mechanical pump has been covered at The Diesel page. Doing this swap will loose the factory cruise control however. You basically graft a old mechanical pedal to a newer one for the pedal position sensor. The SES light will stay on also.
    FWIW, John Kennedy has made 260+RWHP with his electric pumped(4L80E) 6.5TD. With extensive mods thou. I haven't heard of anyone pushing the envelope with a mechanical 6.5 either. I've thought about juicing up a '92-93 6.5 with 5sp and seeing what numbers come, but I'll most likely drop the CTD in a call it a day /forums/images/graemlins/grin.gif.
  9. Supergas
    Supergas 1/2 ton status
    Oct 17, 2001
    161
    Texas Coast
    I have a 95 Suburban, 2500, 4WD, 6.5 TD, that has 208,000 on it. I use it every weekend and for towing a large boat (or anything else I want to tow) I have the latest pump, with everything else stock except the 3" exhaust. It will not run with my buddy's 7.3 Excursion uphill, but will do everything else plus gets 18 MPG & costs about 40K less. This is my third 6.5 TD & I would recommend it to anyone.
    The main problem with a diesel is that most people don't understand how they operate & get lazy with the maintenance.. such as oil changes, filters, fuel additives etc. Read the info on Diesel Page & follow their instructions & you will be fine.. Have Fun Dieseling.
