Need some paint help
Discussion in 'The Garage' started by K5DRAGER, May 5, 2003.
  1. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    Going to try to paint the Blazer this weekend if the weather works out. The ? I have is, the paint I bought is acrylic enamel and was wondering what I use to thin it. Doe they sell enamel reducer? And if they do what ratio do I thin it or will the reducer can tell me that. Any help would be great. I used to work in a body shop about 10 years ago, but its alot different when you don't have all the products right there for ya. /forums/images/graemlins/1zhelp.gif
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Enamel reducer will do the job reducing.
    As to what the ratio is for the cut, either the paint, or the reducer will state it on the label's. /forums/images/graemlins/blush.gif
  3. K5DRAGER
    Jul 27, 2001
    1,164
    Momence, IL
    Thanks Don ! /forums/images/graemlins/thumb.gif
  4. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Anytime! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  5. bee32
    bee32 1/2 ton status
    Aug 6, 2001
    401
    Virginia Beach Va.
    It all depends on temp and humidity. Just thin it enough to where it will run off a screwdriver(should use a ZAHN cup) and start to drip from the end in about 3 -5 secs and that should be sufficant for spraying. Always shoot a test spot on something else prior to shooting your rig. Let that set up for about 45 mins and look to see the results. if it looks good then shoot your rig.
  6. K5DRAGER
    Jul 27, 2001
    1,164
    Momence, IL
    Thanks for the tips bee32. /forums/images/graemlins/thumb.gif
