Need some rear spring help....
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Skyetone, Apr 30, 2002.
  1. Skyetone
    Skyetone 1/2 ton status
    Apr 10, 2002
    118
    SLC Utah
    Tore out the rear axle over the weekend and the driver rear main eye leaf is bent and the pass side litterally was broke in half. They are stock springs with a 4" block. I want the cheepest way to replace em. I was going to go get a rear set from the J-yard but was told that 69-72 is a different beast than other springs. But then in the mags it shows rear springs from 69-89? FS. so WTF? can I go get a stock set of springs from any truck or k5? What about a truck pack? Anyone have some 4" lift springs FS for the rear? Or would I want a 6" rear? I want the static shackle it's a tow rig.
  2. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    You can use any 52" rear springs. These came on Blazers/Trucks all the way up to '91.
    BTW, .... it's your FRONT springs that are unique to 1st generation trucks.
    Marv
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I bought SuperLift 5 1/2" rear spring packs several yrs ago and they have worked out great for me so far!! I run Rancho 4" up front and this combo makes my rig sit level with the hardtop on. With it off (all the time 24x7 year round) my rear does poke up just a bit. Beter than saggin!!/forums/images/icons/smile.gif
  4. Skyetone
    Apr 10, 2002
    118
    SLC Utah
    Glad to hear it's the fronts that are unique..... That helps out alot.
