Need Some Tech Help Please....
Discussion in 'The Garage' started by HEAVY METAL, Jan 25, 2006.
  1. HEAVY METAL
    HEAVY METAL 1/2 ton status
    Jan 10, 2005
    386
    Maple Ridge B.C. Canada
    i recently put a dana 60 in my blazer... turns out its a dodge... the spring perches are different cauzing my springs to move inside the shackle towards the outside of the truck.. any quick fixes for this in the busshing dept?
  2. yellowchicken77
    yellowchicken77 Newbie
    Dec 23, 2005
    3
    antioch, ca
    i just did the samething, i put a set uf dodge front and rear in my 73 k5. The best thing you can do is make freinds with some one who ca weld (stick, it has more tensile strength) And re weld the spring perch on. Oh and your going to have to weld on new shock mounts the dodge one wont work
  3. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    yup he's right there is no easy fix
  4. HEAVY METAL
    Jan 10, 2005
    386
    the shocks work fine...i've had this diff in my truck for a couple months now out with it three times n/ps just noticed the rear of the springs movin towards the outside of the truack in the shackle
  5. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    if you have polyurethane bushing you can easily trim the outers to make the springs sit at the right distance. 1/4" outward on each side and you're golden.
  6. HEAVY METAL
    Jan 10, 2005
    386
    its rubber right now but am going to get urethane on staurday...so i trim the outter piece?.. what holds the bushing in place then? im con fused lol
  7. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Do a search on this.
    You may have to go pretty far back but there was once someone who spec'd out the bushing numbers to offset the springs the correct way.
    Anyone remember these part numbers?
  8. HEAVY METAL
    Jan 10, 2005
    386
    oh mna please... i've searched and searched.. and searched.. lol..please?
  9. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    That may have been Az-Kickin that did those offset bushings (now that I've been thinking about it for a while.)
    Rene
  10. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    I searched for a while the other nite and only info I could find was everyone talking about the setup from AZ Kickin...
  11. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Sure, there's an easy fix. The difference is 1 1/2", right? Make a set of zero rates, but offset the center pins 3/4" to the side instead of front to back. You may have to clearance the underside of the spring plate, but it's still not a big deal.
