Need some tips on the stupid hub lock ring
Discussion in 'The Garage' started by MudFrog, Oct 4, 2004.
  1. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    One of the lock rings for my hub is being stubborn, no matter what I do I cannot get it free. This is the outer lock ring, the one you can not use pliers on. I spent two hours poking and prying with screwdrivers on Saturday and still could not get it loose /forums/images/graemlins/angryfire.gif
    Any tips to try, they are usually a pain but they have never been this bad.
  2. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    This is the one on the groove at the outer most edge of the bearing hub, right?
    If it seems to be stuck and needs to be broken loose I'd take a hammer and small punch and try to make it rotate in the groove. Once you know it's not stuck go get some good quality picks and start digging again. Be careful with the picks as they can break so grab some safety glasses just in case.
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Ditto on the picks , they help . What I do is take a small screwdriver and hold one side so it wont rotate , and then pick the other side in the opposite direction , once your under it leave it there and take the srewdriver and put it in the gap you just made and pry it out /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    what i do is take a very small screw drive and work my way under it mear the end, then take a pick that is bent 90* and get under the edge with it and pull up and while moving the screw driver around it to help pull it up. never failed me, only had one give my problems and i just kept at it doing this. /forums/images/graemlins/dunno.gif
  5. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    When you do get it out bend the ends a little bit so next time you will be able to use a screwdriver to get under the end.
  6. Wingnutt
    Wingnutt 1/2 ton status
    Feb 20, 2000
    324
    NOVA
    Actually, what I've found that works best for me is that hook shaped O-ring pick. It slides right under the locking ring they you can pull it out of the groove and slide it all the way around the hub and the ring pops right out. /forums/images/graemlins/peace.gif
  7. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
    lots of patience and a pick! last ones i pulled i used a electrical circuit tester and a small screwdriver! /forums/images/graemlins/histerical.gif
  8. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    good tip.. /forums/images/graemlins/thumb.gif
    or you can grind the ends so they look like this
    i'll help for the next time. /forums/images/graemlins/waytogo.gif
  9. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    I'll get a pick tomorrow and try it. /forums/images/graemlins/thinking.gif
  10. dcell152
    dcell152 Registered Member
    Sep 23, 2004
    84
    Nothern Maine
    That is an great Idea /forums/images/graemlins/waytogo.gif /forums/images/graemlins/bow.gif /forums/images/graemlins/waytogo.gifI wish I had thought of that a long time ago it would have saved a lot of agravation
  11. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    I use a scribe... which is what I think was discribed earlier.
