NEED SOME TIPS!
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Quetzal_SJ, Apr 3, 2001.
  1. Quetzal_SJ
    Quetzal_SJ 1/2 ton status
    Feb 20, 2001
    123
    San Jose,Ca USA (BAY AREA)
    Hey Everyone,
    Ok my 71 jimmy came with what looks like two sets of body mounts red/black. I don't have the instructions. Any helpful tips on the best way to atempting to replace them?Also any links to tech articles would be great. I figure I better swap them before I get started on the body work to be sure that everything lines up and that the body sits right on the frame.
    Thanks Quetzal
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I would buy EnergySupension mount kit. Get the Black poly mounts. They are said to be impregneighted (sp?) with polygraphite to stop poly squeek.
    When I did mine I replaced all the bolts and nuts. Oh and if you have body shimms from the factory make sure to keep them in the same place. GM used shims to level or rigs on the frame.
    <A target="_blank" HREF=http://www.burt4x4.coloradok5.com>http://www.burt4x4.coloradok5.com</A>
  3. Dieselmh
    Dieselmh 1/2 ton status
    910
    Texas
    Do you know what lengths I would need for my 1970 Blazer. I have new bushings, but that's it. I need to know what else I need. My bolts are really bad and I think I'm gonna have to cut them out.
    Diesel
    Who says that size doesn't matter?
  4. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    I posted the size and lengths of bolts needed to the old Blazer-Net. I'll have to go searching through my notes so I can post them here.
    Also get a couple of cans of PB Blaster. You will need it to (hopefully) loosen the hold that all of the rust will have on the bolts, nuts, and bushing sleeves. Apply at least a week before tackling this joh, and apply more every day until the time comes to do the job. You will also likely need a grinder of some sort, a BIG hammer, and a STRONG punch for the stubborn bolts.
    FWIW, I have a set of black Energy Suspension polyurethane body mounts. They are just polyurethane. There is no graphite in them.
  5. Burt4x4
    6,854
    Ya know Steve I don't even remember were I heard/read that but fer some reason I have that stuck in my head that the black ones don't squeek like the red ones do....I guess asking Energy would clear this brain fart of mine[​IMG]
    When I did mine I just got a long carriage bolt and ran it thru then marked it for a mesurement then bought the right sizes that way...
  6. Roostr84
    Roostr84 1/2 ton status
    Aug 19, 2000
    451
    NJ
    Burt I remember hearing that too but i dont know if it was in referance to body mounts or to suspension bushings etc. i know companies like PST imprgnate their suspension bushings with graphite.
  7. Quetzal_SJ
    Feb 20, 2001
    123
    Thanks for the info guys. One question, do I have to loosen all the bolts then lift the body a little then prop it up to do the swap?
  8. Burt4x4
    6,854
    When I did mine I used a small bottle jack to lift only the area I was working on. Basically tried to do two mounts at a time with the jacek inbetween the two. I would/did not loosen all the body mounts just cuz I didn't want the body to move much from the position it was in. So I would just keep the area your working with loose and not the whole deal. You don't need to lift the body all that much any way just an inch or so....
    Good Luck youll love the ride whenits done! I did anyway..
  9. Steve_Chin
    Mar 6, 2001
    1,126
    I did one side at a time. I loosened all of the bolts on one side a little, then the other side (the side I was working on) a lot. Then I removed the one bolt at the mount point in which I was interested, lifted the body using a 2x4 and a floor jack (2x4 to spread the load across the tub), changed the mount, inserted a bolt, and set a nut on the bolt loosely, then proceeded to the next mount.
    Oh, I used an ink pen to mark a couple of alignment points between the body and the frame. Nothing moved after the swap-out was complete.
  10. 72GMCJIMMY
    72GMCJIMMY 1/2 ton status
    Mar 17, 2001
    142
    I just bought a 70 piece body mount/ radiator core mount kit from LMC. It has all the bolts, nuts and washers. It is an as original type rubber mount kit. I ordered the poly mounts first. When they arrived I was not very impressed, they just seemed too hard. Has anybody gone to poly and found them a problem?
  11. gassman
    gassman 1/2 ton status
    Jul 12, 2000
    131
    Quincy Cailf, Plumas County
    Also make sure you have your top on. I changed all of mine with it off last summer and when I put the top back on it didn't fit right. Had to loosen all of the body mounts to bolt down the top then re'aligned the mounts
