need some u-joint help
Discussion in 'The Garage' started by BIGDAN112686, Apr 22, 2004.
  1. BIGDAN112686
    BIGDAN112686 1/2 ton status
    Nov 20, 2002
    112
    nc
    alright guys, i busted the ujoint on my rear driveshaft while driving to school today(dont ask how, i wasnt even on the gas when it happened) so anyway, i got the replacement and plan on fixing it where it is broken(sitting in my parking spot at school) i was hopin you could give me some help on how to fix it and what tools will be needed. thanks in advance. /forums/images/graemlins/thumb.gif
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Needle nose plyers, ballpean hammer, and whatever size wrench for the caps.
  3. BIGDAN112686
    Nov 20, 2002
    112
    nc
    thanks, do you think i need to jack up the rear and take off pressure or will it be ok with out doin that?
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i always use an axle lock pin shaft to drive the caps, and an oversize socket to drive the opposite cap into(put socket on surface first and then set driveshaft u joint cap above it so that cap can go inside of the socket,.
    pretty easy really,.
    once youve done it youll always know how /forums/images/graemlins/laugh.gif
    the clips will be tight, knock the cap with the axle lock shaft once or twice to get pressure off the clip so it will easily remove, and trhen drive the u joint opposite way to get the opposite end clip to remove easier.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Make sure you smack the yoke with a hammer once real sharply to relieve any binding. Make sure the u joint travels without any binding, it should move freely. If it doesn't, smack it again.
    If you use greasable joints, MAKE SURE YOU GREASE THEM FULLY WHEN YOU INSTALL THEM. That means until grease purges from ALL FOUR CAPS. If you don't, it WILL fail prematurely.
    When I install joints at work, I put them in a vice (to simulate the locating tabs on a yoke) and grease them until all four caps purge.
    I personally don't use greasable joints, but if you do, grease them correctly upon installation!!
