need specs.!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FLWIV440, Dec 4, 2000.
  1. FLWIV440
    FLWIV440 Registered Member
    Nov 21, 2000
    32
    this may sound weird but what exactly is pinion bearing preload? Also what are the torque specs on the pinion nuts(front 10 bolt and rear 12 bolt) after preload is set?would appreciate any help.
  2. FLWIV440
    Nov 21, 2000
    32
    can't anyone give me an answer? sure is a lot of differential talk at this sight. someones got to have something dont they????
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
  4. FLWIV440
    Nov 21, 2000
    32
    thanks found an even better sight,www.differentials.com.sight is called west coast differentials. has everything you need to know. By the way if anyone wants to know,pinion bearing preload is set first to determine correct pinion depth and to insure that the depth will not change after pinion nut is tightened(300 to 400 foot pounds).
