Need Spring Measurements
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazer74, Apr 19, 2002.
  1. blazer74
    blazer74 Member Premium Member
    Oct 18, 2001
    1,158
    74
    Brighton Tn
    I am trying to determine if my front springs are 4 or 6 inch lift. I need the measurements from a 4 inch lift and a 6 inch lift front spring taken from the front bottom lip of the the bumpstop bracket to the top of the spring forward of the u bolt plate. I get 11 inches. 74 k5 Thanks, Craig
  2. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    I get about 9 1/2" on my 81 Jimmy. Old 4" Rancho lift...
    Rene
  3. blazer74
    Oct 18, 2001
    1,158
    74
    Brighton Tn
    Mine are old too. I believe they are superlift, They also have a degree shim under them. They were on the truck when I bought it back in 1986.
  4. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    there was a great post about ride heights that Stephen Watson started a while ago. Do a search for it or just keep looking back in the archives. I think that most 4 inch springs don't come with degree shims, while many 6 inch lifts do.
    Again, check that post about ride height, once you read that and do some measurments on your truck, I doubt you'll have much of a question about what lift weight you're at.
  5. Grim-Reaper
    7,385
    Atlanta
    The thickness of the spring pack also needs to be figured in. It would be best to measure to the top of the axle tube.
    I'll get you the measurment on my rancho's tonight.
  6. blazer74
    Oct 18, 2001
    1,158
    74
    Brighton Tn
    Good point about the spring pack, Grim do you have lift springs on the back, if so any sag problems with the rancho's. Once I determine what lift I have I'm going to replace my rear springs. Justin I'll check on that ride height search. Thanks to all, Craig
  7. blazer74
    Oct 18, 2001
    1,158
    74
    Brighton Tn
    Great info on ride height, Would be a great ref in the tech section. Will have to remeasure mine.
