NEED Spring Plates and U-bolts for a D60 BAD!!
Discussion in 'Parts & Trucks Wanted' started by RingMaster4x4, Dec 26, 2001.
  1. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    That is what I need. Thanks.
    If you build it, the mud will fly!
    72 K5 blazer with a 427 tall deck and TH350/NP205 and 9"of lift with 40"tires.
  2. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    if you are having a hard time finding them you can get them at the dealer...i think they run in the 50-60 area each...i lucked out and found a wrecking yard that had some...they just gave them to me because they said the normaly threw them away anyway..[​IMG]
    <font color=green>Chaz</font color=green>
    [​IMG]<a target="_blank" href=http://community.webshots.com/user/chaz88k5>http://community.webshots.com/user/chaz88k5</a>[​IMG]
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    I have brand spanking new plates to fit any K30, front and rear, $100 shipped to your door.
    The front plates were $80 after freight and taxes.
    The rear plates were $40 after freight and taxes.
    I'm not picking my nose...I'm just pointing at my brain!! [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    I must be retarded. I did not read very carefully that you needed just the FRONT plates. [​IMG]
    I can sell you my new front plates for $70 shipped to your door. Don't have any u-bolts, though.
  5. Chaz88K5
    2,979
    Stockton/Lodi CA
    i might need the rear ones...could you mesure the distance between the holes goin accross the spring...the ones i have now are too tight next to the spring and screwing up my u-bolts...center to center mesurement would work..how much do ya want for the rear?
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Chazz, before we go any further, I want you to know these plates are the true K30 rear plates. These plates mount on the BOTTOM of the axle tube. The u-bolts to fit these will point DOWN, not up like on the Blazers and 3/4 tons.
  7. Chaz88K5
    2,979
    Stockton/Lodi CA
    i have a set of thos already....where would i get the plates for the top...the plates for the 3/4 ton was not wide enough for my springs...am i goin to have to make something myself??
