Need steering Help!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zakk, Sep 26, 2001.
  1. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    I just got the new D60 in the front end of my '77 K5 and steering is not what it was with the D44. I cannot turn right more the 1/3 of the way. what is the best way to correct this? steering block? dropped drag link? lowered pitman arm? i cannot trust salesmen, they wanna sell me whatever the big $$$ item is. any help/suggestions on what would work best would be WONDERFUL!
    -Zakk
    SB 400 TH350 NP203 p/t 6" Lift D60 14BFF 4.10's 36"Wrangler II's
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    From what you show on your sig, you have 6" lift.
    Did you install a 3" steering block on the D60's driver side knuckle? If not, get one. That should restore your steering a bit more.
    Do you have a drop pitman arm? If not, get one of those, too. The pitman arm and D60 block should be enough to correct the problem. You may still need to adjust the draglink, too.
    For best steering results, convert to crossover steering. I know its $$$, but it will be better in the long run.
    <font color=red>I'm a "black top mudder"!!!</font color=red>
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>http://coloradok5.com/gallery/thatK30guy</a>
  3. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    draglink adjustment might be necessary
    Surfing is Life...
  4. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    a mechanic said my drag link was well worn, &amp; that he would install a "s" drag link (he said it, i have never heard of one) would this piece be better? i think i have a buddy with a block...
    -Zakk
  5. TheGeneral
    TheGeneral 1/2 ton status
    Feb 22, 2001
    556
    NC, USA
    Go with what previous said, but check preset stop nuts too, or whatever the hell they're called. 6 inch should go to crossover in my opinion if you want good steering through suspension's movement.
    If you ain't hurt, you ain't playin' hard enough.
    The General
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    That "S" drag link is an aftermarket piece from Superlift and some others.
    I do not like them. The joint ends seem to wear out faster than regular straight factory drag link ends.
    I would get a new drag link from your local parts store and install the 3" steering block and a 2" pitman arm.
    When you put the drag link together, dab some anti-seize on the threads so you can adjust the thing later.
  7. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    the s draglink is a POS. dont use it.
    crossover is your best bet followed by the previously mentioned corrections. you will still get noticeable bumpsteer with the chev factory style steering.
    crossover will cost about $100 for the pass side steer arm, $65 for the pitman, you are on your own for the 2wdr steering box and 1.25" .219 DOM
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    I beg to differ.
    The passenger side steering arm does not cost $100.
    I paid $185 for the arm from ORD.
    Unless you know of some "cheaper" arms?
