Need suggestions for radiator upgrade
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shum1, Jan 17, 2001.
  1. shum1
    shum1 1/2 ton status
    Oct 8, 2000
    270
    UTAH
    I'm tired of the marginal cooling capacity of my stock radiator in my 1990. Not to mention it leaks. Is there an economical upgrade that will still let me use the stock shroud and have provisions for auto tranny? Thanks.
  2. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    I had cooling prob's with my radiator, so I ended up pulling 1 off a suburban with a 6.2 diesel. Alot larger, cheaper, and it basically bolted right in. Used my existing support and shroud, but shroud doesn't completely cover up radiator. Haven't had a cooling problem since.
    <font color=blue>Professional <font color=red>JEEP EATER</font color=red>, it's a population control thing.</font color=blue><P ID="edit"><FONT SIZE=-1>Edited by 4gunz4x4z on 01/17/01 00:41 AM (server time).</FONT></P>
  3. dyeager535
    26,975
    i'm kinda curious as to what the later trucks (88-up pickups) used for radiators. GM was pretty standard on radiator size. For example, in the F-bodies (firebirds/camaros) they went to an aluminum radiator. Surprise, Surprise, it also fits in the A/G-bodies. (78-88 Monte Carlo, Cutlass, etc.) Its a one row radiator with MUCH better coolant capabilites. Wondering if the later trucks got an AL radiator that is the same dimensions as ours??
    Dorian
    My K5 and Chev/Olds tech/links page: <A target="_blank" HREF=http://yeagerd.home.mindspring.com/index2.html>http://yeagerd.home.mindspring.com/index2.html</A>
  4. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    try 1-800-max-cool, ask them for the upgraded radiator for your application.........js
  5. Here is the run down on my 4 core install PN\'s
    I just put a 4 core in my 88 Suburban and it ran me about $200 for the whole enchilada. The 4 core PN 433730 was a new one I bought through Auto Zone for $179.00 and the upper mounting bracket PN 14018600 was GM along with the four rubber mounts PN 6264100 for the top and bottom. Easy install too. I hope this helps you out. E-mail if you have any questions. Not sure about the shroud.
    [​IMG]<font color=red>BigBurb[​IMG]
    <font color=purple>IF YOU'RE SCARED, SAY YOU'RE SCARED !!
