need suggestions....where to start?
Discussion in 'The Garage' started by bigbadchev84, Jul 12, 2006.
  1. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    ok i need direction onhow to make my truck more universal, street,mud,hills,sand and trails. this is what i have currently:
    1984 shortbox
    dana 44 front-4.56s
    14bolt rear-4.56s some sort of locker?
    39.5x18x16 boggers
    strong 350
    sm465-hydro clutch
    208 x-case
    3/4ton drivelines
    8inch front springs/zerorate installed straight up
    8inch rear springs/zerorate straight up
    hydroboost brakes
    so im up for suggestions as to what to do, i like the hieght it is at now or maybe a little bigger, i just dont wanna lose much, but i guess if i have to then so be it. this thing does awesome in the mud now, but thats it, not very good street manners the steering dosent feel to tight, i am up for a steering brace and some new tierod ends soon
  2. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    I think that if your not afraid to trim your wheelwells then lower the truck maybe two inches at least and trim for clearance. That way you will lower you center of gravity(help on trails) and the new springs will have less of an arc so they should ride nicer(help on street)
  3. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    CROSSOVER!!! you wont believe the differance!
  4. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    anyone know of a way to get into crossover onto a 44 for cheap?
  5. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
  6. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i have the same susp set up (8" springs + zero-rates) and im swapping to 5" 64's and shackle flip in rear then 4" 52's up front, that way ill have about the same lift, but will flex 10x better. cross-over is so much nicer trust me. i started out with the push pull with 8"....boy world of difference. do it you wont regret it one bit
  7. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    what all is involved in the 64s? is the 5" spring a lift spring?
  8. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    yep they are 5" lift springs. you might have to relocate your gas tank as well. you have to relocate the spring brackets. for ease of install you could switch over to 4" lifted 52's and a shackle flip, that will give you more flex and keep you at the same height your at now.
